Question about Weber One Touch Silver Charcoal Grill
Coal starts dying out the moment I put the Grill
After lighting the coal red hot, the moment food is put on the grill and covered with the lid, it seems that the fire starts dying out with all the bottom and top vents open.
Has it anything got to do with it not being windy or high humidity in the air?
Even with all the vents open the air is restricted with the top on. This is what makes the kettle such a remarkable cooking machine. If you wish to grill then leave the lid off and cook directly over the coals, if you are grilling a thicker cut of meat such as a 1 1/2" thick porterhouse you might want to put the lid on for a while to more or less bake or broil the meat without blackening the surface of the meat and to achieve the desired internal doneness of the cut. you can also stack your briquettes/lump to one side and put the lid on so the exhaust is opposite to create a non direct cooking environment for cuts such as butts, ribs, briskets, whole chickens etc
Posted on Nov 17, 2011
How are you supposed to heat up the green egg
There are you tube videos. I temporarily take daisy vent cap off top of egg, open bottom vent door wide open, light lump coal 2-3 spots with a loof lighter (from ace hardware) and then close lid. I have one section of galvanized dryer vent from Lowes that I stick on top which accelerates preheating of egg. Once the temp gets to 500, I remove the section of vent by grabbing it with a glove or hotpad. Wait a minute or two for smoke to die down. Place daisy back on top and close bottom vent door down to 1/2" and close daisy 1/2 on top and this should drop temp to 175-250. Use fine adjustments 1/6-1/8" until desired temp is reached. Your food can go on at any time after removing dryer vent. Just burp lid by slightly lifting to allow any heat burst to escape. I also have a gas conversion that works awesome. I just add a small smoke ox over burner that provides enough smoke on front end of cooking process. Advice- keep the butts and ribs on for 6 hours.
May 01, 2014 | Big Green Egg Extra Large - XLHD...
I added coals to my Charbroil Deluxe 7000 grill, and then they disintegrated. Have I ruined the grill?
Is the grill that you are using gas? If so make sure it is compatible to use with coals. You might also be looking for briquets.
Jul 28, 2012 | Grilling
I'm trying to locate a replacement coal grate (perferably in stainless steel) . Can you supply one? Thanks tlynch@inficon.com
Sorry, we don't sell anything on FixYa. However, if you get the dimensions of the grate you needand search around on Google for some the Grill Parts & Accessories sites and you're more than likely to find what you need. I will caution you, Stainless Steel Grates are expensive. Plus, they do not do well with charcoal. The charcoal gets so hot against, that it will pop and pit. It's not like doing it on a gas grill, where the heat is moist and the stainless retains it's integrity. Unlike coal or charcoal, which is an extremely dry heat. You may be better off with Cast Iron. Once it's seasoned, it should do better than Stainless Steel.
Hope this helped you. Please let me know. Thanks/
Jun 21, 2011 | Patio Classic 2000 Series Grill
How do you condition a new grill?
Start some coals with the grate off the grill. As the coals are heating up, coat the grate in *vegetable* shortening using a paper towel. Place the grate back on the grill over the hot coals and cover. Allow the coals to burn off; this process will coat the grate with a protective layer of oil.
You might also consider running the grate through a burnoff process BEFORE curing to remove any coating the manufacturer used for protection during shipping. To do this, burn some coals for roughly 30 minutes under the grate with the lid down, let cool, then condition per previous instructions.
Jun 24, 2010 | Brinkmann Smoke 'n Grill Double-Grill...
Cooking info
You can print a new manual off of www.chargriller.com. But, the basics are:
1) Take cooking grates off of grill
2) Put enough charcoal on the grill to cover the desired cooking area two coal layers high
3) Pile up desired amount of charcoal (laid out in step 2)
4) Spray lighter fluid all over charcoal pile
5) Light the pile
6) Let the pile burn until the flames die out and most of the coal has turned white
7) Spread the coals back out (use tongs they will be hot). Put any coals that are still black on top of the white ones.
8) Put your cooking grates back on the grill and let the last black coals turn white and the grates heat up.
9) Now cook!
Apr 14, 2010 | Char-Griller Super Pro
The coals are perfect and hot, but the fire goes out before the f
With charcoal you light the coals and wait till they have turned white and the fire will have gone out by then but it will be very hot and will last an hour or more.
Jul 11, 2009 | Weber One Touch Silver Charcoal Grill
Forgot how many coals to use for Weber 18 inch grill
as much as it takes to cover the bottom of the grill that is under the food..ex..if grill is covered with food then make sure the bottom is covered and spread out evenly. If just two types of meat make sure the bottom under them have coals not necessary to cover whole bottom..if any help please rate me and let me know..
Jul 10, 2009 | Weber One-Touch Gold 18.5 Grill
Low temperature
I have the same smoker but not this problem. Is it possible that you have not let the coal get hot enough prior to putting your meat in it. When I feel that the temp is not hot enough I try to leave a little crack with the lid to allow air to flow from bottom to top stoking the coal. When you get the nack of it, this thing cooks an awesome turkey.
Sep 22, 2008 | Brinkmann Smoke 'n Grill Double-Grill...
Weber One Touch Silver Charcoal Grill Logo
157 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
