Question about Husqvarna Daisy 310
OUR Husqvqrna 5310 suddenly started sewing backwards
The machine will only sew backwards no matter what control is moved.
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Problem is probably with the feed stepper motor or the reverse cams are locked. What happens when reverse button is activated. If no change it's probably the feed stepper motor. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 14, 2010
My machines stitches backward instead of forward.
There is a forward and reverse switch you are missing. If you have a pedal it is a matter of pushing the pedal the right direction.
Jul 26, 2014 | Singer Inspiration 4205 Mechanical Sewing...
My friend bought jenome sewing machine. It is working very well except that it only sew in reverse (backwards). Could it be that the reverse button got stuck or is there a setting that needs to be done?
button in centre of stitch length control is probably gummed up and stuck lubricate with penetrating oil and wind stich control backwards and forwards to see if centre knob starts to move. Remove arm top cover and do same to mechanism visible from above
Feb 19, 2014 | Janome Sewing Machines
Singer 4166 suddenly started sewing only in reverse even when forward mode checked
open the top of the sewing machine. Then press the button or lever that changes the forward reverse mode. You may find that something got stuck there where it should effect the machine part. May a drop of oil on that spot can help?
Jan 11, 2014 | Singer 4166 Sewing Machine
My Pfaff 1211 was working and all of a sudden it
Your hook where your bobbin case goes in are most likele jammed with cotton. give it some oil and turn your handwheel backwards gently. Look if you see any cotton jammed and remove it
Jan 20, 2010 | Sewing Machines
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
Bernina 1090 only sewing backwards
1.Turn the bobbin winder off.
2.You have to reverse the wires on the carbon brushes.
3.Make sure that you have the needle in correctly- with the flat side to the back. Those machines rarely go out of time.
Jul 22, 2009 | Bernina Sewing Machines
Quantum XL-1000
ok it sounds like either the gear on the rotoary hook is bad "lot of money to fix" or there is a small pin that moves the feed dogs make sure it is setted correctly. also make sure the pressure foot is down all the way.
Dec 10, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Bernina 930
Have you ever done a thorough internal oil of your machine? These mechanical machines rely on oil to keep moving but, over time, that oil dries and starts to stick things together. I do a deep internal oil about annually and oil the hook at least every 8 hours of sewing.
Wheel on right side that controls the needle up and down is very tight...
There's an oil diagram in this answer:
http://www.fixya.com/support/t26371053-am_looking_bernina_930_service_manual
How do you open bernina 930 sewing machine especially removing the side...
Feb 24, 2018 | Sewing Machines
Sewing Machines Logo
344 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
