Question about Magix Music Maker 12 Deluxe
After starting studio 12 deluxe., the program asks for the initial disk to be put into the drive, even althogh it is still there. It won't do anything else. How do I fix it?
  • 729 Answers
Hi sweeneyr95
Try to look on these solutions:
1.Some programs have more cd´s for the installation, maybe it is another cd you need to insert ??.
2.Maybe it is the cd that is corrupted (scratches and similar) maybe you can save the cd with this program (Unstoppable Copier):
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Unstoppable-Copier.shtml
3. There can bee need to get the Support Team of Magix :
http://support.magix.net/magix_relaunch/php/page.php?page=request
4. Your cd/ dvd player is not working. Try to insert another cd and see if it can read the contents.
Hope this will help
Have a nice weekend
Please rate my answer
Posted on Sep 12, 2009
Magix studio 12 deluxe will not install on my windows 7 OS is there a patch or am i out luck
If a program cannot be run under Windows 7 because of compatibility issues, which is the case with Magix Music Studio 12 Deluxe, you have to right click on the executable file that will install the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before (probably Windows XP).
You will have to do the same thing for the application start program after installation.
You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 10, 2010 | Magix Music Studio 12 Deluxe
My PC ask fwk.exe ! I use Vista Home Premium. What to do about it?
Hi and Welcome,
fwk.exe comes out when trying to open or launched your Studio program. You need to uninstall Studio program then remove all the folder from Pinnacle.
Here check this step by step procedure on how to delete all Pinnacle Folder.
>double click on my computer
>Local drive c:
>look for Program Data. Take note that Program Data is not visible then all you have to do is to click on Organized>folder and search options>click on view and put check on show hidden files and folders and click okay.
>double click on program data then go ahead and delete all Pinnacle Folder
>double click on program files then delete all Pinnacle folders
>double click on Program files X86 same thing.
>go to control panel>(program and features if Vista), program and security if Windows 7, add/remove program if Windows XP then uninstall Studio.
>restart the computer after wards.
>install Studio 12
Once again check if still the same problem.
Regards,
Sep 26, 2010 | Pinnacle Studio Ultimate 12 for PC
Installed correct on vista openns to studio but
This due to the some errors in the magix music maker.this can be corrected by re-installing the program or make it re-pair.
Jul 09, 2010 | Magix Music Maker 12 Deluxe
Hi im frank, the setup.exe. says that this program cannot run in DOS mode please help.
Go to RUN and type D:\i386\winnt.exe, (where D is your CD-ROM drive), to start Setup
If D isn't your CD/DVD drive change letter accordingly
Apr 14, 2010 | Magix Music Studio 12 Deluxe
Freezing magix music studio 12 deluxe with vista 64 bit
I think the problem is..... Magix is compatible with XP 64 bit but not with Vista or 7 64 bit, not much 3rd party software is.
Sep 12, 2009 | Magix Music Studio 2005 Deluxe for PC
Can't install disk 2 for photo explosion deluxe 3.0
Does it appear to be loading anything from the sisk or does it just turn the access light on and do nothing? It could be the second disk is damaged. Check the back side of the disk for a fingerprint mark or scrathches. clean off the priint and try again.
Does the disk read ok in File Explorer, try opening a file and see if it can at least access the disk dont matter if it cantb open the file because it doiesnt have a program that can open it, you are just checking the readability!
Jun 23, 2009 | Nova Development Photo Explosion Deluxe...
Cannot finish install of Hallmark Cardshop Deluxe 2009
ERROR 1305 is an error code returned when the cdrom can't read the disk either because it is a bad disk or a problem with the cdrom drive, I would contact this site:
http://www.hallmarksoftware.com/support/support.aspx
it may solve your problem. call them on the phone, tell them the problem and they may be able to help you.
May 26, 2009 | Hallmark Card Studio 2009 Deluxe Full...
Im having problemx installibg sims deluxe edition
Dear mz_bridg_ett,First of all you need to check that your computer hardware/ the entire computer meets the specifications of the game. you will be looking at things like
CPU speed -- the higher the number in MHz you have the better
RAM speed -- this is your computers' memory, the bigger the number in MB/ GB and MHz the better
HDD size -- this is your hard disk drive, bigger the number in GB the better. . . . typical size is 120-500Gb and will be enough for the game . . . . . . more than enough even with Windows (EWWW YUCK!! ) installed on it.
GPU speed-- this is your graphics disply, and like the rest, the bigger the number the better, best to check out your specifications before you attempt to play the game.... ideally you want a direct x 9.0c card or better still direct x 10 when in windows (YUCK) go to start>run>command>dxdiag ... this will check that for you
Right with that lot done, open your CD drive, and put the install disc into the drive, and it should start to run automatically. . . . if not go to my computer and find the CD drive letter and double click it. . . . . if you are a smarty pants like me, then you can go to start>run>command>X:\autorun.exe...........substitute value "X" for your drive letter, you can also type....start>run>command>X:\setup.exe..... for Vista (awwww ewww awful) then you need to go start>all programs>accessories>command prompt> command.com...... then follow the above for other version of windows.
game should start to load, ask you where you want to install it, and then for the password/ product key of the game, which you can find on the back of the manual or on the reverse inside of the CD case.
enter the code then hit ok
When this is done, itll ask you to enter the game disk/ play disk if you dont have to reboot your computer, but i always reboot first anyway.
enter the play disk and run it like you did before with the install disk, unless you are one of the many masses that add shortcuts on your menu and systems to start up your programs/ warez.
if this doesnt work, try cleaning the disk, try installing it to different locations, even get diagnostic tools to check your computer. . . .
definitely try all above before feeding the game disks to the dog.
I hope this is the fixya for you
yours sincerely
Oz
Mar 13, 2009 | EA - Electronic Arts The Sims Deluxe...
Magix Music Manager
Is it really asking you for ur software installation CD?
Most probably it may be asking you for your Operating System Installation CD. Please insert the Windows 2000 SP4 CD into the drive and try continuing with the installation
Best of luck
Have a nice day
Feb 01, 2008 | Computers & Internet
Magix Music Maker 12 Deluxe Logo
145 people viewed this question
Top Magix Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Magix Computer and Internet Expert? Answer questions, earn points and help others
