Question about NetGear WGR614 Wireless Router
I am given a set up error while trying to configure netgear WGR614. Below is the message The router is setup with the static IP values read from the computer. However, there is no Internet connection with these settings.
  • NetGear Master
  • 32,281 Answers
You need to contact your Internet Service Provider to obtain the setup configuration for the cable or DSL modem. A LAN cable is then connected from the modem to the Internet LAN port on the wireless router.
Normally you do not set a static IP address on the router, and the wireless card should be set to obtain an IP address automatically.
If you still have problems, give me details of what configuration steps you have carried out on the router and the wireless card together with the error messages.
Posted on Sep 12, 2009
How to configure static ip
This WEB site shows how to configure and some usefull advice.
http://www.tomshardware.com/forum/41067-42-setting-static-addresses
Mar 27, 2013 | NetGear WGR614 Wireless Router
Tip
Configuration of NETGEAR router as Access Point: The below steps illustrates the...
The below steps illustrates the usage of router's like WGR614, WGT624, WPN824 as an access point to extend the wireless network in your location. The only required setup is that you should have a DHCP server running on your network ( be it your modem or a different router).
1. Connect a computer directly to NETGEAR router on any of the four LAN ports.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on wireless settings in the left hand side menu Under Setup.
5. Change the network name SSID to some other name.
6. Select security options as 'WEP (Wired Equivalent Privacy)'.
7. Set the 'Authentication Type' as 'Automatic' and Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Click on LAN IP setup from the left menu.
1. Change the IP address of the router from 192.168.1.1 to a free IP of your existing DHCP network.
2. Also disable the DHCP of the router by unchecking the box for 'Use router as DHCP Server'.
3. Click apply and click ok for any popup message that arise.
4. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, turn off the router and restart the computer.
Now, connect the two router in the following way:
1.Connect Ethernet cable from the Lan port of the existing router/modem to the Lan port of the NETGEAR router.
2. Powercycle both the routers and your computer
3. You may connect other computers' directly to NETGEAR router or wirelessly as per your requirement.
on Mar 18, 2010 | NetGear WGR614 Wireless Router
How do I reset my router and connect it to a different computer?
Look for a little hole that reads reset and press it with a little pin, hold it for about 10 seconds
Jan 31, 2012 | NetGear WGR614 Wireless Router
I have a Windows 7 Lenovo T510 laptop which has a wireless port. I have used wireless successfully on other networks. When I'm at home, I've got a Netgear wireless router connected to a Motorola cable...
check the ip configuration settings of your wireless computer...make sure that there is no static ip address assigned in your computer... Also check for any duplicate ip address in the wireless configuration... Also tel me what is the exact error message you are getting when you are trying to connect to your network...
Jan 02, 2011 | NetGear WGR614 Wireless Router
How to set a password for netgear
Netgear WGR614 54Mbps Wireless Router
  1. Begin setup of your Netgear Wireless Router by first reading the instructions in the included manual, and following their guidelines for plugging in and initializing the access point. The first few steps in this guide should coincide with the information found in the manual, however we will follow up with important information on how to secure your wireless access point.
  2. After powering up the router, use an ethernet cable to connect your computer to one of the ports on it marked 1 through 4. Next open a web browser window on the connected computer and typehttp://192.168.1.1 into the address bar and press enter. This will take you to the Netgear Smart Wizard welcome page, click OK to begin the configuration. The router will attempt to detect the type of connection you have and the next message you receive should be Dynamic IP (DHCP) Detected, click Next once you see this.
  3. Next you will enable the wireless capability of your router. In the dropdown box for the region where you are located select United States from the list. On this screen you should also change the Wireless Network Name (SSID) from its default value to something unique so that your Base Station will not be confused with another. Click Next.
  4. You should now see a message confirming that your connection is working and wireless is enabled. However, your are not secured yet. Read the notes and click Done. Then direct your browser tohttp://www.routerlogin.net to continue the configuration. A window will pop up prompting you for your login and password, enter admin for the username and password for the password, then click OK.
Aug 23, 2010 | NetGear WGR614 Wireless Router
Trying to connect netgear wgr614v9 router to new toshiba computer with windows 7 ....setup says unsupported operating system....what do I do
As netgear setup disc doesnot support Win 7.
U need to manually setup the netgear product
-- hard resett the router using a restore factory setting hole on the back of the router
-- open the netgear router page using www.routerlogin.com
-- Username - admin , Password - password
-- run setup wizard
-- if it detects dynamic ip then press next
-- and on the left u will see wireless settings under setup .
-- secure the network using WPA_PSK(TKIP)
-- and then apply .
In case if it will detect static or fixed ip .
Then click on " Basic settings "
-- Under router MAC address
-- select "use computers MAC adress "
-- Apply
-- And then Powercycle the network..
-- And u will be able to go online ..
Jan 02, 2010 | NetGear WGR614 Wireless Router
Can't get connection through router to internet
Hi,i beleive you have checked with your service providor as to what type of IP configurations is required.That is if you have a static Public IP or multiple IPs.If you have already checked the router configurations make sure your PC or laptop is configured accordingly.That is you have to configure your PC or laptop in a DHCP way.You can go to control panel from Start option and then go to network wizard,you will have 2 options,the 1st one would be assigning a static IP and then the next one would be Obtain an IP automatically.Click on the radio button there.Restart your comp and the router.You should be good to go.
For any further assistance please revert.
Apr 09, 2009 | NetGear WGR614 Wireless Router
Problems with netgear wireless router
picolas and nannysboy,
You can setup your router any way you like after accessing it. You don't need software for NetGear. All you have to do to access the control panel is:
  1. Open your browser.
  2. Type in this ip address - http://192.168.1.1
  3. Configure the router as you see fit. It's fairly simple and has built in help guides.
If you cannot connect by wireless, do the above while connected by a LAN cable (looks like a telephone cable, only fatter and wider).
The router should be connected as follows:
  1. WAN port directly to cable/dsl modem.
  2. Any port (1-4) running out to your computer.
Please let me know if this helps. Good luck!
Feb 24, 2008 | NetGear WGR614 Wireless Router
Can't connect to XBOX Live because of Strict Nat settings Netgear router WGR614
Using Xbox Live with NETGEAR Routers
NETGEAR has Xbox certified routers!
Note that the listed, certified firmware may no longer be available; later firmware is likely to work, but is not certified unless listed.
There is no information on what will be certified in the future. But if an existing model does not appear on the product dropdown on NETGEAR Home Page, then it will not be certified.
If using older routers such as RT311, RT314, RT328, RH348, RP114, or RP334, or if you have problems with connecting to Xbox Live, refer to the Microsoft Xbox Troubleshooting page.
Other Troubleshooting Information
  • Upgrade to the latest router firmware.
  • Open ports 88 and 3074. (There are non-NETGEAR sources that say this is unnecessary, however it is.) For a description of opening ports, see How is Port Forwarding Configured?
  • The MR314 works with 3.26 firmware, using port forwarding.
  • There is no known workaround for the RO318.
If your Internet connection uses PPPoE, set these filters:
Filter # A Type Filter Rules M m n 1 Y Gen Off=2, Len=3, Mask=ffffff, Value=002145 Y N N 2 Y Gen Off=13, Len=1, Mask=ff, Value=01 Y N N 3 Y Gen Off=24, Len=2, Mask=ffff, Value=0303 N D F If your Internet connection does not use PPPoE, try these filters:
Filter # A Type Filter Rules M m n 1 Y Gen Off=12, Len=3, Mask=ffffff, Value=080045 Y N N 2 Y Gen Off=23, Len=1, Mask=ff, Value=01 Y N N 3 Y Gen Off=34, Len=2, Mask=ffff, Value=0303 N D F
Nov 07, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
107 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
