Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Proble with old model of saeco superautomatica electronic twin
Machine lighting 2 red leds - no start - only sometimes. I make 2-3 caffe - is ok. Any time after push start-stop key ist this problem - all red lamps is on.
  • 24 Answers
Most likely a component, i suggest returning for service or replaceing
Posted on Dec 13, 2007
Hi i have just taken over a caffe and have a vienna coffee and chocolate machine can you tell me my local coffee and chocolate supplyer for gosport. many thanks Karen Davis
Better deals are to be had online than through a local dealer (almost without exception), to seach online for someone selling the amounts you want at the best price. I find http://www.pianocoffee.com/ best but DYOR.
Aug 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
I have the Vienna Superautomatica. It turns on, the green "on" light ilights the red light blinks on and off. The grind button has no effect. Nothing is clogging the grinder - sometimes there...
Hi
Blinki9ng red light usually something is not in place. The water tank empty. grinder empty or cloged, the brew unit not seated, dredge drawer not in place, or the usual cluprit is the drip tray. There can be something behind the drip tray that is keeping it from seating ( it has to lock into the 2 holes in the bottom of the base) Try to push the drip tray in and down and see if it will work.
May 16, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Sup018 model. Changed flowmeter and sensor because of water flow problem. Now the unit makes one cup and red light comes on. Turn off machine to reset. Pump work fine, no clogs anywhere. Any...
hi
i had the same problem , you placed the chip with 3 legs on the wrong side turn it over and it will be ok .the writing on the chip of flow meter should face down.
Apr 12, 2011 | Saeco Vienna SuperAutomatica Coffee...
After the macine has warmed up, we push the button...
There are a couple of sensor switches on this machine to prtect user and also machine. flashing red right is the worning of some sensor is reporting unusual situation. Can I suggest you to check left side ground case is cleaned and pushed enough in to main unit, open the front upper door and check if brewing unit is staying right, water ok, having coffee, etc.
May 21, 2010 | Saeco Vienna SuperAutomatica Coffee...
No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
Mar 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Limited water output (saeco vienna superautomatica model year 04)
Could be 3 things. Pump, flow meter, or clogged boiler. Pump is a standard ulka pump, flow meters are bought only from saeco as well as boilers. If i had to guess.... If its a vienna black than i'd point to the flowmeter. If you get pressurized water out of the steam wand than its either the flow meter or the boiler. Pointing more towards the flow meter (u shaped white plastic part with in and out tubes.
Jan 31, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
813 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
