Question about Olevia LT37HVS 37 in. LCD HDTV
Won't Turn on after power outage
After a power outage with the TV on, my Olevia LCD will not turn on. The has happened twice. The blue Olevia light will come on, but the TV will not. This happened once before last month and after 3 days, the TV started working as normal. Now, the 2nd time around, I'm waiting for 3 more days to see if it will start working again. Does anyone know if these TV's have some sort of reset button or internal protection that can be overridden. Fingers are crossed that the TV starts working again in 3 days. If it does, I'll be buying a UPS for the TV immediately.
SOURCE: Olevia 42"
@givemhall: I had this happen to my 42" after I moved. It turns out that when we were carrying the TV, the power button got pressed down too hard (it's right near where you would put your hand to lift the set) and it was stuck in the ON position. We took the TV apart and fixed the switch, then the TV worked like a charm. It's about an 45 minutes worth of tear-down, but we were ecstatic when it came back to life. Hope this helps you!
Posted on Aug 11, 2008
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
As suggested in another post, w2power has provided this solution. It is the only thing that has worked for me thus far. While it is a pain, I can at least consistently get my set to turn-on when using this USB cable method with logged-in PC attached to Olevia's service port (I have the 23" version)
From w2power:
"I think this model has a timer on it, it seems to go when the warranty runs out, not proven but Mine went out about a month ago. My only fix is to plug my tv (via the service port which is COVERED) to the usb port on my computer using my BlackBerry usb cable, in other words the Mini USB. Seemingly I must be logged on to do so and wait for the Chime form my pc, a balloon will pop up for new hardware not recognized (vista) then press the power button and then it turns on, unplug the usb cable and make sure the source is set to tv / video or else it will power back off and you will have to start all over. Theres NOT A PERMANENT fix yet but this is what I do every time I want to use the TV, I have a laptop so I use it as the Monitor just to watch movies. If you have a desktop I recommend keeping the cable handy BUT DO NOT LEAVE THE USB CABLE IN FOR LONG USES. THE SERVICE PORT IS COVERED FOR A REASON!!!
Posted on Oct 09, 2008
SOURCE: Syntax Olevia 30" LCD - blue screen, then black screen, sound is on
you have a broken inverter board. I have a LT30HV, and it had the same problem. The inverter board supplies power to the backlight. Swap it out with a good one, and you're back in business.
To test, take a bright flashlight and point it at the screen just an inch or so off the surface. If you can see your picture, then you have a blown inverter.
it may not be worth fixing it. Wait for a good sale on a new one. My inverter cost about 150, and it was a remanufactured part. Not as good as the original part as it flickers just a tad. I had to take the entire TV apart, with pieces literally everywhere. My cats loved it.
Posted on Nov 15, 2008
  • 5568 Answers
SOURCE: Olevia 242T 42" LCD HDTV - Suddenly No Picture, Nothing Works
 I heard they were restructuring their company or something.
There has been a change ownership from Syntax-Brillian to Olevia International Group.
Details of Olevia brand
Unfortunately for all of us (we have 747i) service seems very poor and the failure mode you describe doesn't give me any clues despite 40+ years of service experience.
Ours is still 100% but I now suspect our trouble will come.
Posted on Nov 28, 2008
  • 9 Answers
SOURCE: Olevia LT26HV LCD TV won't turn on
Olevia has problems with the power supplies. Best solution is to remove the back of the TV. On the 542 it is about twenty number 1 phillips head screws. locate the power supply connectors check the board for the voltages, clearly marked on the PCB. Continue to check the voltages by powering on the Television. all voltages should be within its described range. If a voltage is low or nonexistent, the power supply is bad, usually a bad capacitor.
There are three series of caps, on the low voltage side it is 16 volt, next 24 volt and finally 36 volt (these are just max ratings.
which ever power that was found low the cap would be near that voltage output connector.
next step is to remove the board and replace the capacitor, using a soldering iron and making sure to solder with no slop.
with the board on an insulated (nonconductive surface connect the board to the televion. Check voltages and if no other voltage issues reassemble.
Posted on Sep 05, 2009
SOURCE: olevia tv screen turns itself off after several minutes.
Ive got the same problem with my tv its very frustrating. Im glad Ive done some research to find out the problem. It seems everyone is saying Olevia has problems with the Inverter boxes on their tvs
Posted on Dec 09, 2010
0 characters
1 Points
Tv won't turn on no blue light either
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 14, 2014 | Olevia LT23HVX 23 in. LCD Television
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is:
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
Olevia 37" LCD TV will
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Aug 20, 2011 | Olevia LT32HVM 32 in. LCD Television
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
My Olevia 237-s12 TV won't turn on. When we push the power button, the blue power light flashes on/off repeatedly. We have unplugged the TV to reset the system but no change. Is it shot?
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like, to buy a refurbish power supply board for the replacement.
Hope this helps in solving the problem.....
May 07, 2011 | Olevia 237T 37 in. LCD TV
I have an Olevia 42"
The issue you are having is your power supply
Thank you
Dec 07, 2010 | Olevia LT42HVi 42 in. LCD Television
My Tv, Olevia LCD HD TV 242 FHD T11, will not turn on
Same thing Just happened to me ths AM. Acting Wierd then this morning fuzzy screen and poof won't come back on.
Comcast box was resetting at the exact same time and I found this online....
Mar 06, 2010 | Flat Panel Televisions
Olevia LT37HVS 37 in. LCD HDTV Logo
1,043 people viewed this question
Top Olevia Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you an Olevia Flat Panel Television Expert? Answer questions, earn points and help others
