Acer 3640 battery
My battery is not charging anymore..what should i do? i used it for only 1year,please help me,,i dont have money to buy a new one...tnx,,how..
  • Big Daddy
    Big Daddy May 11, 2010
    unfortunately if your batteries cells are dead and you want to use your laptop you'll have to run it on AC power. to use it as a portable device again you will have to purchase a new battery. There is a hack for laptop batteries, where you take the cells out of 9 volt batteries. You then take your laptop battery back apart and test each cell for positive and neg. then sketch the configuration. you then use the cells from the 9 volts you've disassembled to reassemble your laptop battery from your sketch. Making sure you match the positive and neg. if your are unsure how to do this, Please buy a new battery.
    Genius:
  • 1,252 Answers
Check with some other power adapter also
Posted on Sep 12, 2009
Charging pad the remote batteries are dead, won't hold charge anymore...
Sadly that's how they make the new rechargable batteries for controllers. You are supposed to recycle that and buy new. Luckily you can find chargers for the wii very cheap nowadays. I have used a few different chargers and have found the Nyko brand ones are junk so steer clear of those. The Duracell induction chargers however work very nicely. You just set the wii remote down on the charge pad and it charges fairly quickly. My kids run around and even if the remote shifts a bit it will continue charging. Hope this helps!
Apr 22, 2013 | Nintendo Wii Remote Control 4 Charging...
Acer aspire will not turn on or charge
Hello bperez28,
There are 3 possible reasons for that problem.
1. Battery is dead or is not seated properly. Try removing the battery from your laptop and then replace it back. If the battery is dead, it will not charge anymore. If it is still under warranty, ask for a replacement.
2. Charger is malfunctioning. Try to plug it into a different know working plug outlet. You might need to replace the charger with a new one.
3. Motherboard issue. Needs servicing.
You need trial and error to know exactly which of those is the reason why your Laptop is malfunctioning. Try a different charger/battery BEFORE buying one.
You can contact ACER directly from this link:
ACER SUPPORT
I hope this helped you out.
Thanks for using Fixya.
You can rate my answer if you appreciate the information I gave you.
Oct 06, 2011 | Acer Aspire 5100 Notebook
Battery charge immediatly and discharge immediatly
hey dude.. i am facing ur problem 2 well i solve it by luck first step u should turn it off and get out the battery after couple of hours return the battery back and charge it again dont charge the phone more than 2 hours and use it normally DONT MAKE PHONE CALLS AFTER CHARGING IMMEDIATLEY w8 for 1 day and then it wil be fixed ;) if this dont work go to the store and buy a new ****ing battery ;) this phone have money problems ;(
Feb 20, 2011 | LG KF510 silver on Orange Pay As You Go...
Battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Jul 15, 2009 | Acer Aspire 5920 AS5920 Notebook
My battery wont charge.
Hi I am Vortah The red light is usually an indicator that the battery is charged however in this instance as you are saying it isn't the battery has possibly gone short and you will need to replace the batteries . They have a type of internal memory and only charge a certain amount of times before they no longer accept charge and merely overheat during charging .. But I have to say it may be possible the charger is faulty as if the internal rectifier that charges the battery has gone short that may also bring the red light on in some chargers .. so try the battery or as I would do take it along to your nearest dealers and get them to check it . it may save you money in the long run you could be buying a battery you still cant use when you actually need a charger .. Hope this helps regards Vortash
May 29, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
Sony t30 LITHIUM BATTERRY
It is possible that the battery is defective. This is a common cause for what you are describing. To verify this, you will have to try another battery. You can take the camera to the nearest Sony service center to verify this if you don't want to try a new battery first.
Jerry G.
Nov 25, 2008 | Pentax Optio S50 Digital Camera
Acer Aspire 5580 poor battery
Its time for a new battery. After a period of time of using a battery, the amount of charge it can hold depletes. Even if you always have it plugged in. Usually, batteries only last 18-24 months which is sad, seeing how much they cost. I'm a computer tech and see this problem everyday first hand. The best thing you can do is buy a battery from eBay and save yourself a bunch of money. Local retail stores charge up to 3 times as much for a battery. Good luck and I hope this helps..... :>)
May 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
