Question about Bosch Axxis WFL 2060 Front Load Washer
The pump on the Bosch WFB 2000 front loading washing machine doesnt seem to be pumping all the water out, it leaves about 40mm of water in the drum. It though pumps and seems to be working, as it does pump some water out but leaves some.Can you help
    President:
  • 1,653 Answers
  1. Check the filter is clean.
  2. Check that the outlet pipe is completely clear of debris and soap / detergent scum.
If this does not cure the problem then it may be there is soimething trapped in the water pump or thst the pump is actually defective which will mean a new pump is required.
To keep the machine clean of waste build up and to keep any bad odors away
  1. Remove all items from the washer.
  2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
  3. Close the washer door and dispenser drawer.
  4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
  5. Press Start and allow cycle to complete.
  6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
  7. Repeat the cleaning procedure monthly
Posted on Sep 12, 2009
Bosch WFB 2005 Pump Cover Stuck
You can replace the pump and not have to buy a new machine.
May 19, 2012 | Washing Machines
I get a gravelly sound from my bosch wfd2473 washing machine, mid way through the cycle,the drum seems to work ok, would it be the pump making the noise or is there a test i can do.
bosch wfd2473 washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 02, 2011 | Bosch WFL 2063 Front Load Washer
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 08, 2011 | Bosch Washing Machines
Hi there I have a bosch wfb 2005 with a drum that doesnt turn at all. It turns/spins freely by hand & is quiet but whether with or without water in it, it doesnt turn at all! Made a lot of noise on...
hello the belt could have snaped if ok check the brushes on the motor 2 plastic blocks either side of each other hope it helps
regards
shaun
Jan 04, 2011 | Bosch Washing Machines
Replaced the sump pump, now the machine will not
There will almost certainly be something stuck in the pump again. Possibly the same thing that happened to the last one.
May 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
My WFB 2000 washer is not pumping the water from the main drum...where is the filter to empty it and find why the water is not emptying?
If the pump is working and not burned it seems that the filter is bloked the filter is at the lower base; open the front lower cover and you can see it.
BY thanks
Mar 10, 2008 | Washing Machines
Bosch WFB 1605 washing machine
i am so upset with my fancy $1100 plus washer that doesn't work that my husband wants to cart it to the dump
Jan 31, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
709 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
