Question about Concept CC-2502 Car Audio Amplifier
I need a rebuild kit for the concept cc-2502
Parts are blown if you know where to get a rebuild kit call (309)699-2905
    Guru:
  • 1,326 Answers
Lol, there is no rebuild kit for an amplifier. You will need to go to radio shack or an electronics store to get the replacement parts. Try this site
http://www.mcmelectronics.com/
Posted on Sep 14, 2009
  • James Brooks
    James Brooks Sep 14, 2009
    lol, there is no rebuild kit for an amplifier. You will need to go to radio shack or an electronics store to get the replacement parts. Try this site
How much rms dose amp have?
Concept CC-2502 2002 900 watts max Rms
Feb 24, 2011 | Concept CC-2502 Car Audio Amplifier
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
96 wildcat 700 only has half power like it only runs one cylinder have spark on both
You probably have a bad clutch seal on your crankshaft, or one dirty carburetor, or possibly bad spark plug caps. Clean your carburetors, change your plug caps, and test drive the machine carefully. If it still bogs , buy an after market piston kit with crankshaft seals, gaskets, pistons, and rings. Do a complete rebuild it should only cost about $150 for all the parts in a kit. Then you should be good to go for another 17 years.
Dec 29, 2010 | Interactive Toy Concepts Crossfire Arctic...
I dont know how many watts it is
4 Ohm Stereo Power (RMS): 250W X 2
4 Ohm Mono Power (RMS): 850W X 1
2 Ohm Stereo Power (RMS): 450W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Length: 16.93"
Width: 11.66"
Height: 2.37"
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Dec 23, 2010 | Concept CC-2502 Car Audio Amplifier
My bostich framing nailer leaks air from top and will not shoot
do you already have the rebuild kit??. Could be a cut o ring the cylinder seal might be cracked , there are quite a few items to check, specifically where is the air coming from, the exhaust, if so then I would look for the items mentioned. It would be best to download a breakdown for the tool and if you are mechanically inclined start disassembly laying parts out in the order removed and also maybe take a few quick pics to help you in reassembly. they are not that hard to rebuild. Let me know and I will see about the breakdown and rebuild kit for you but I need the model number and give me some general area you are in and I will try and find parts somewhat locally
Oct 03, 2010 | Stanley Bostitch N80s Nailer -rebuild...
31 cc leaf blower won't start. After many pulls it sounds like it might want to fire but only for about a second and then nothing.
This is probably a fuel delivery issue....carburetor related. My experience with these engines was that it needed the carburetor rebuilt. There are diaghram and rebuild kits available for these and at most you would maybe spend $15 for the kit. Rebuilds have more parts but diaghram kits sometimes cure the problem and cost less. All diaghram kit parts are included in a rebuild kit also.
Aug 13, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
What speakers
Hello enot99,
The CC-2502 is a bridgeable 2-channel amp. If you want to drive normal speakers in stereo, the best would be a good set of components with separate woofers, tweeters, and crossovers. They are available in many sizes from most car audio manufacturers. I'd begin by finding out what speakers fit the location where you intend to mount them. Then I'd browse the speaker selections in that size at www.crutchfield.com. You can also use the "outfit my car" feature to browse only the products that fit. Then select a pair that has a power range and impedance to match the amp: 250 watts RMS at 4ohms or 450 watts RMS at 2ohms.
If you want to use the amp in bridged mono mode to drive a subwoofer, again Crutchfield has a large selection of subs and some enclosures already fitted with subs (loaded). The amp claims 850 watts RMS into 4ohms bridged, so look for a sub that has a power handling rating of at least 850 watts and it needs to be 4ohms.
Hope this helps.
Aug 02, 2009 | Concept CC-2502 Car Audio Amplifier
I have a 2400 watt concept amplifier and if i turn it up too much it sends a real loud hum throught my subs. I really want to get it fixed because this has ben a very good am to me. If i need this repaired...
yes that cause from yhe gain is too high on the amp and you getting a ground loop traveling thru the rca signal
once the gain is high you will hear it make adjust on amp
Mar 29, 2009 | Concept CC-2502 Car Audio Amplifier
The amps are probably going into protection mode. The wires are most likely not hooked up correctly. Make sure you have a good ground, good power source, and the remote wire is run correctly. Also make sure the speaker output wires aren't touching each other, and you have the correct ohm load for the amp. What kind of speakers/subs are hooked up and how are they wired?
Sep 20, 2007 | Concept CC-2502 Car Audio Amplifier
Concept CC-2502 Car Audio Amplifier Logo
149 people viewed this question
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
