Question about Whirlpool ET9FTTXL Top Freezer Refrigerator
Refrigerator part not cold
It seems as though there's blockage from the freezer to the refrigerator
    Sergeant:
  • 222 Answers
Manually defrost the refrigerator/freezer. Be sure that it's THOROUGHLY defrosted and that the defrost water runs freely into the tray underneath the refrigerator.
ALWAYS clean the bottom coils, a FREE fix that is the source of COUNTLESS problems with the refrigerator inside and out.
Plug it back in. If that doesn't solve your problem, you've either got a physical blockage between the compartments or the flap/linkage that controls air flow between them is stuck (closed).
If you don't know how to access these components, it's time to call the repairman.
Hope this helps.
Posted on Sep 12, 2009
  • David Mcintosh
    David Mcintosh Sep 12, 2009
    Hope this helps.
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
Maytag refrigerator mtb1954eewoo does not seem to be as cold as it should be air doesnt seem to blow
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 26, 2011 | Maytag Refrigerators
Refrigerator not cold enough and freezer is too cold making food very hard? water seems to leaking on bottom of freezer and refrigerator.
Refrigerators with attached freezers typically keep the two compartments at predetermined temperatures, but failure of some components can lead the refrigerator to seem warm while the freezer portion completely freezes.
Fan Issues
According to the appliance website Appliance Aid, many freezers contain a fan that blows cold air throughout the freezer and into the attached refrigerator. If this fan fails, the site explains that the freezer may become too cold; the refrigerator will not receive air circulation from the freezer, though, and will remain warmer than normal.
Air Damper
Appliance Aid also notes that most refrigerator and freezer combinations contain a damper that regulates the flow of air between the two compartments. If the damper sticks or fails to function properly, it may restrict the flow of air from the freezer to the refrigerator. The result of a failed damper would be a completely frozen freezer and a warmer than normal refrigerator.
Hope this would help.
Good day!
Sep 06, 2011 | Kenmore Refrigerators
Fridge not cold enough, Freezer ok
The refrigerator gets its cold air from the freezer section through ducts and damper control. Check for blockage.
Apr 27, 2009 | Candy CPCA240FFK Bottom Freezer...
Freezer cold fridge warm
clean the condenser coil in the back of the unit
Apr 20, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerator doesnt sem to be working right
Ice maker will not work if temp in freezer is not cold enough to keep activated
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting
Oct 08, 2007 | GE Profile PSI23NCR Side by Side...
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Whirlpool ET9FTTXL Top Freezer Refrigerator Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
