Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Waterlevel is not stopping and notwashing - Whirlpool Ultimate Care II LSQ9564J Top Load Washer
    Brigadier General:
  • 3,513 Answers
You may have solved the problem by now....but it is probably a blockage in the level pressure chamber which is eaither a part of the drain pump manifold or a seperate chamber attached to the bottom of the tub. Its easy to find just follow the small pressure hose from the top of the machine. If its part of the drain manifold its not so easy to clear unless you have a large surringe to pump hot water down the hose to clear it.**** REMEMBER TO UNPLUG THE APPLIANCE FROM THE POWER SUPPLY ******
Posted on Sep 12, 2009
Diagram of pressure switch
I hope this answers the info you need.
http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
May 29, 2012 | Kenmore Elite Washing Machines
After being switched on it doesn't get started.
You will need to check the voltage that is available in the inlet valve, the waterlevel sensors , the motor and the drain pump/valve to establish if the program controller is working.
If not the controller is faulty.
Sep 28, 2010 | LG WM-2277HW Front Load Washer
No current to waterlevel switch. switch is good.
this would be a normal case, the switch is powered only during the fill stage, it is an interrupter.
Sep 05, 2010 | Kenmore 14249 Dishwasher
I have a Sears Kenmore washing machine The water does not stop running on any level and over filled the washer. Sears said it wash the timer so i ordered it, replaced it and it still does not stop...
More likely the water level sensor is faulty or blocked..
As the water level rises, air is pressed through a tube which is connected to the water level control knob. If the control is faulty or the hose is diconnected the machine will fill, and overflow.
Best bet is to call a serviceman and have the waterlevel controller checked.... Not a big job..... Good luck.... Nomess
Aug 04, 2010 | Washing Machines
Waterintake stops after approx. 35 sec.waterlevel is to low,detergent compartement will not open because of low waterlevel and also water will not heat, because heating element is not covered with water....
The machine fills by time only as you have already determined. The intake screen on the water valve is probably plugged up and cleaning it should solve your problem. You will have to turn off the supply to the dishwasher and disconnect the water feed line. Eric
Sep 15, 2009 | Dishwashers
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
My NEC NW 652 washing machine is showing an E9 fault. When i hit the power button the E9 message appears
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
Jan 13, 2009 | Washing Machines
Dishwasher
  1. could be a latch adjustment-- push gently on the doo when you hear the chatter. could also be something lodged in or near the level switch-located around the waterlevel--check manual
Aug 28, 2008 | KitchenAid Dishwashers
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Too Much H2o
either your waterlevel switch is bad or the hose from the tub to the switch is leaking air. more info would help..ie do you have to turn the water off at the wall for the water to stop rising or do you just have to push the timer knob in?? let me know, i can definitely help to diagnose!!
Apr 24, 2007 | GE WSM2700W Unitized Spacemaker Washer and...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
