Freeview- tv displays "No (or bad) signal - Televison & Video
  • 525 Answers
Check for cables between DVR and TV. you can change them by new one and see what will happen
Posted on Sep 12, 2009
  • check for cables between DVR and TV. you can change them by new one and see what will happen
I can't receive HD channels
Roy, change your cable, must be faulty and not giving a signal to TV.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 02, 2016 | Blaupunkt BLA32/147 32" LED TV 1920x1080,...
I bought a television from a second hand shop, but because theres no manual i cant set it up, its suposed to have built in freeview but we cant work it out
No,all small CRT tube analoge tvs types are getting analoge freeview signal only.U trying to hook this tv up now for for freeview will not work because it are all digital format signal now.Tries websites like Amazon.com,Ebay.com buy a box call Digital Coverter box hook this box betwwen the tv the in incoming freeview AIR broabroast tv signal will able to get a digital signal.Or u must have pay cable or satallite broadcating signal to used a analoge CRT tube tv now.
Jul 28, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My neighbourgh can get freeview tv just using his old ariel, i on the other hand can not. have i done something wrong with the tv set up. thanks
Probably not. Freeview signals are hundreds of times weaker than the old analogue signals, so will show up every single problem on a badly maintained, badly installed old external tv aerial.
In most areas, a tv set-top aerial is a waste of time and even a loft aerial may have problems. Any aerial system which is not direct from the external aerial to the tv can also suffer problems, as each Y-splitter and joint wastes an awful lot of signal.
Your fix is to get a proper modern aerial system fitted. If it's well designed and installed with the proper parts and cabling (does not necessarily mean most expensive) then it should last for another 30 or so years and ideally won't need signal amplifiers.
Note that although your neighbour gets reception, he probably suffers regular picture break-up, freezing and /or pixellation especially in poor weather unless the aerial was in top condition beforehand and was relatively modern.
Jul 12, 2011 | Televison & Video
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
No Signal On D/TV
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Samsung LE26R72B 26 in. HD-Ready LCD...
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Sep 16, 2009 | Hitachi Televison & Video
No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Nov 24, 2008 | Televison & Video
We have purchased a Phillips freeview box but am unable to get a signal !! We have the tv arial plugged into the back of the freeview box into the tv and the scart connected from freeview to tv. Do we...
Yes
If the Freeview box is not connected to the main aerial socket, you cannot get a signal.
Also, you will need a digital aerial, if you don't already have one.
Jun 09, 2008 | Philips Televison & Video
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
