Question about Whirlpool SF310PEK Gas Kitchen Range
My whirlpool gas stove has the igniter getting red hot but it doesn't light up the oven
  • 63 Answers
Replace the igniter. It is not strong enough to fire the gas.
Posted on Sep 12, 2009
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
How do I light the oven on a gas stove
If this is a newer stove (that does not have a pilot light...and most newer stoves don't), you shouldn't have to light the oven manually (if you think you need to, you have a faulty stove). Manual ignition of a stove is also potentially dangerous as larger amounts of gas in the oven can cause small explosions. Most modern gas stoves use a very hot glowbar to both regulate the amount of gas entering the oven and igniting that gas. If you have a faulty glowbar, it will not allow enough gas to enter the oven and may not be hot enough to ignite the little gas that does enter (that is why you may smell gas). It sound like you may need to replace the glowbar (or visually inspect the glowbar to see if it gets red hot. If it does, it may still be faulty (not drawing enough power). The only way to test this is to use a clamp-on ampmeter and test the current flow through the wires feeding the glowbar. They should read between 3.1 and 3.7 amps. Anything lower means the glowbar should be replace. If you cannot see the glowbar get red hot, you have an electrical problem or a circuit board problem.
Jul 11, 2009 | Maytag CWG3600A Gas Single Oven
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Whirlpool GS445LELS Gas Kitchen Range
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
I HAVE A WHIRLPOOL GAS OVEN AND GRILL AKG667 MODEL NUMBER 853566715000 WHEN THE GRILL OR OVEN ARE SWITCHED ON THE FUSE CONTINUALLY BLEW. I CHECKED THAT THE CONNECTIONS WERE OK. NOW WHEN THE...
hi thanks for the question so the igniter works but no gas most of the gas stoves have the same problem if the igniter works but no gas could still be the igniter the igniter must get almost white hot to ignite the gas if id does not the gas wont lite so the ather problem is igniter lights but no gas problem is with the 2 coils on the gas valve replace those thanks the appliance doc
Sep 17, 2008 | Whirlpool Kitchen Ranges
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Whirlpool SF310PEK Gas Kitchen Range Logo
104 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
