Ink cartridges I have bought two black cartridges.They both stopped working when the graph showed half full. Is this the fault of the cartridge or the printer?
  • 41 Answers
What do you mean by the graph was on hald, do you mean when it appears on the computer screen or what because if so it might be the case that your ink catridges are half full but they have dried up
Posted on Dec 10, 2007
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
The printer tells me to replace an ink cartridge because the ink has been depleted. The cartridge is nearly new, though. Just yesterday it showed to be half full. I have cleaned the printheads and the...
There is a chip on your cartridge that communicates with the printer to estimate how much ink is left in the cartridge. When the chip thinks the cartridge is empty it will refuse to print any more pages no matter how much ink is left in the cartridge. These cartridges are only estimated to print "up to 840 4" x 6" photos, or 80 13" x 19" photos." If it showed half full yesterday and then you put through a large print job it is very likely the cartridge is empty. In any case once the chip thinks it's empty the cartridge needs to be replaced.
Nov 09, 2009 | HP Photosmart Pro B9180 InkJet Printer
Dell 968 aio printer won't print black
I replaced the ink cartridges even though the levels still said they were half full. It worked perfectly.
Sep 22, 2009 | Dell 968 All-In-One Printer
Not printing black
Hi
1. Make sure that you have removed the plastic cover from the cartridge nozzle .
2. check if your black ink cartridge is full - put the nuzzle on the tip of you finger if it leaves ink drop then it is full and should print ok , if it didn't leave ink on your finger then it is dry and you should buy new cartridge .
hope it helps
Jul 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP Laser Jet 1320. Orange light next to triangle symbol keeps flashing. This began after a paper jam. I cleared the paper jam but can not get the light to stop and so it wont print. I have shut it off...
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Apr 09, 2009 | Office Equipment & Supplies
Black ink cartirdige not recognized
That sounds like a defective chip on the cartridge. Return it & let them check it (if they can)...
Mar 25, 2009 | Canon PIXMA MP520 InkJet Printer
Problem with new ink cartridge
More that likely the refilled ink cartridges are faulty and should be replaced. While some folks have pretty good luck with refilled cartridges, it is generally better to stick with the new ones.
As to the problem with old cartridges, keep in mind that the estimated ink levels are just that - estimates. However, if your printer has an option for cleaning the cartridges, try that before chunking them. Take them out, put them back in, and run the cleaning process. Sometimes the nozzles can get clogged up and running the cleaning process will clear them up. ( DO NOT TRY TO CLEAN THE CARTRIDGES MANUALLY!)
If none of this helps, you will more than likely just need to get some new cartridges. - Graye
Oct 29, 2008 | HP PSC 1410 All-In-One InkJet Printer
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
k24674
jasbo
jasbo
