when the bass hits hard it turns off and my amp goes on protective mode, i have it on a sony explod 1200 watts 4 ohms..... i dont have the jl 12w3v2-d6 i have the older one, jl 12w3-d6
it depends if the amp is mono or stereo and if it is bridged. if it is bridged the amp cant handle the speaker the best way is to lower the level on the amp or connect it to only one channel. also you might want to check your ground cable use a thick one and make sure its making good contact with the chassis. this happened to me. luck
Works at very low low level, has popping sound like cone is unseating when turned up, changed sub...
(More)
Works at very low low level, has popping sound like cone is unseating when turned up, changed sub speakers and no change, can the amp be prematurely clipping-thats exactly what it sounds like- I am no expert but even at low level(5-10watts) and I turn up the subs volume, it duplicates the same popping noise
i have a 92 chev x cab and want to take the box out of my back seat, i have a lot of equipment to...
(More)
i have a 92 chev x cab and want to take the box out of my back seat, i have a lot of equipment to put in the truck and want to build an enclosure for the bed, what kind of box should i be considering and what dimensions would they need to be for the jl12w3's?
hey i have two pionears in the back of my car and two foculs up in the driver and passenger doors....
(More)
hey i have two pionears in the back of my car and two foculs up in the driver and passenger doors. and i have a kenwood amp powering them... but there not working they just all stoped working at one time i shut my car off and when i turned it back on they werent working but the bass still works... the lite on the amp is just going on and of n usually just glows red n its blinking on and off now so i have no clue whats wong with it i allready checked to see if everything was hooked up the amps but i cant seem to find anything sticking out to me i know they cant be blown because what are the chances of four speakers blowing at the exact same time
hey i recently switched my system from my old car to my new one this time i had it installed by a...
(More)
hey i recently switched my system from my old car to my new one this time i had it installed by a technician. however when i play the subs they are not in sync. the box is sealed and so i ws wondering if it would be the amps equalizer settings or what i can do?
