Question about Toshiba Satellite Pro P300 Notebook
Overeheating on startup and freezing after about one minute of operation
    President:
  • 1,179 Answers
First check your vents to make sure they are free and clear of any dust/debri. A can of compressed air will clean them very well. Then turn it on and listen to see if your fan spins up and blows air out of the vents. If the fan is not working then you will need to replace it before using the laptop or you'll continue with the overheating and could damage the cpu. If fan is working then you can either replace with a better aftermarket fan, or purchase a laptop cooling pad to place underneath while in use. Make sure you always use the laptop on a cool flat surface, never on cloth as that will not allow adequate airflow. Hope this helps.
Posted on Sep 12, 2009
    Genius:
  • Toshiba Master
  • 1,250 Answers
Check whether the CPU Cooling fan is working properly or not
My computer freezes randomly
Hi Petter,
Does the system freeze when you start the computer.
It could be a program that is causing the system to freeze.
1. You Could disable a few startup items like messanger by going to
Start->run->msconfig and click on startup items and disable all and check if the system's performance is better.
Please refer the following MS article if you need clarification
http://support.microsoft.com/kb/331796
2. If this does not solve your issue, uninstall unused programs in your add/remove programs.
3. Perform a disk cleanup following the steps in the below article.
http://support.microsoft.com/kb/310312
This should help you fix the issue, if you still have problems feel free to post.
May 03, 2012 | ASUS Computers & Internet
Freezes after few minutes
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
Sep 11, 2010 | IBM ThinkPad T40 2373 Notebook
The iMac G4 17" freezes cursor moves but nothing works.
Could be a lot of things. Try running Disk Utility from your install DVD:
http://support.apple.com/kb/ts1417
After that, if issues persist, try booting in Safe Boot Mode:
http://support.apple.com/kb/ht1455
If the issue is resolved in Safe Boot, try removing third party startup items:
http://www.thexlab.com/faqs/startupitems.html
If the issue persists in Safe Boot mode, try a new user.
http://docs.info.apple.com/article.html?path=Mac/10.5/en/8235.html
If issue is resolved in a new user, then you know it's something just in your user.
Delete the contents of the following, where ~ represents your user's home folder:
~/Library/Launch Agents
~/Library/Launch Daemons
~/Library/Startup Items
~/Library/Caches
This will usually resolve the issue.
If it persists in the new user, then the issue is likely with the operating system itself. At this point you should Archive and Install:
http://support.apple.com/kb/ht1710
May 24, 2010 | Apple iMac G4 Desktop
Windows freezes after startup
Its better to backup your data - booting from Ultimate Boot CD and backup to an external hard drive.
Try to do regular format or low level format to know the status of the hard disk
Feb 07, 2010 | HP Computers & Internet
Webcam freezes
Try using the camera on another application to see if it freezes there to. If it still freezes then it could be some software that is running in the background. If it doesn't freeze on another application then you know its a problem with MSN.
If it does still freeze then go into msconfig from your start menu by typing "msconfig" in the search box or the run option depending on what operating system your running.
You would click on the startup tab and then disable all to disable all the programs that startup when your boot up into windows.
Reboot the laptop and try the camera again, if it doesn't freeze then at least you know its a piece of software running in the background and you'll have to figure out which one is causing the problem.
If it still freezes then you know its either a problem with the camera or a problem with windows.
Aug 05, 2009 | Dell Inspiron 1525 Laptop Jet Black
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
Well,my laptop(Toshiba Satellite M115-S1061) freezes after startup.It runs good for a couple of minutes, and freezes afterwards. And you can't do nothing after that.
it seems to be your operating system is corrupted it is done by virus try to format ur os drive nad immediately scan ur system with kaspersky antivirus this solves th problem of urs
Mar 18, 2009 | Toshiba Satellite M115-S1061 Notebook
Freezes on startup
just call sony and talk to an operator and they'll send u a box to send your consule to them. You'll need your receipt though.
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
Freezing or shutoff on boot, setup or minutes into operation
Try this:
Boot the system with your Windows XP installation disk. When the boot options window appears select R for recovery console. Once you have logged into the DOS session type: fixmbr and hit the enter or return key and select "y" for yes you want to do this. Type: fixboot and hit the return key again, hit "y" for yes.
May 17, 2008 | HP Pavilion ze2000 Notebook
Toshiba Satellite Pro P300 Notebook Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
