Question about Dryers
Excessive noise when tumble drying - Dryers
    Sergeant:
  • 222 Answers
Most likely the front drum supports (either rollers or slides) are worn out, forcing the drum to slide over an uneven surface. If the drum is supported in the rear on rollers, these could also be the problem. Rear axle/bearing mounted mechanisms can also cause this problem.
Less likely is a worn belt or worn idler pulley bearing. All these components can be replaced by a reasonably skilled homeowner, although the dryer will have to be disassembled to do so.
Hope this helps. Good luck.
Posted on Sep 12, 2009
Water coming from under appliance
Maybe your dryer is not drying!!!!!!!! Is it getting hot? Heat element ok? Maybe the washer is not doing a good enough job during the spin cycle and leaving clothing excessively wet.
Sep 08, 2017 | Refrigerators
Why does my gas dryer make a loud vibration noise?
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
Jul 21, 2014 | Electrolux Dryers
My maytag performa dryer is drying clothes fine and the drum is tumbling the clothes, but it is making a horrible noise. When you turn the dryer on you can hear something inside the dryer unit tumbling...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 13, 2010 | Maytag Dryers
Tumbles but dont dry
74632 is not a model number. But what you have stated the dryer probably has a bad thermal switch. Cost around $6-8. Unplug dryer, remove back, with a tester test everything that has wires hooked to it. Test from one side to the other to see if power goes through, if not replace that part. They are small round or small rectangle with two wires connected to them. Check the one one the duct first, this one usually goes bad. Vacuum out all lint out of dryer and hose to exterior, excess lint will cause dryer to heat up and blow this part.
May 08, 2010 | Kenmore 74632 Gas Dryer
Not drying clothes - have heat and tumble but probably not air Kenmore 80 series dryer.
Your vent is clogged. Remove hose from back of dryer and wall. vacuum out back of dryer, dryer hose an vent pipe in wall, if it goes out at roof you will need to clean out. Moisture from dryer is getting caught in excess lint trapped in vent causing dryer not to dry.
Sep 20, 2009 | Dryers
GE Dryer makes deep sounds when hot and tumbling
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Noisy dryer
hi there,
the rattling and squeeling noise usually comes from the drum shocks. they do wear out due to use. i would recomend replacing them.
Oct 11, 2008 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
