Question about Nokia 6110 Navigator Cell Phone
Wont charge the battery replaced the battery but to no affect
  • 33 Answers
Get your mobile checked
or buy new charger
Posted on Sep 12, 2009
When i plug my P530 in the green light comes on for 1 second and then its off. so it wont charge and camera wont turn on
Not knowing how much you use the camera makes this a harder question to answer. Make sure the battery is fitted correctly but it might be a worn out battery. Using it a lot will eventually wear the battery out and only using it occasionally can affect the battery as it isn't charged.
Are you charging the battery while it is still in the camera? A separate charger is more effective. It might be worth investing in a charger if you don't have one and/or another battery.
Duracell supply both at sensible prices. Nikon CoolPix P530 Battery Charger
Jan 16, 2018 | Green Cameras
2004 polaris ranger battery not staying charged when operating but when engine is off battery not affected cutting out and dying what could be the problem?
battery is being drained as it operates and not taking charge
check tightness and clean both terminals and cables
how old is the battery
may have a dead cell ..wont take charge
check the charging input to the battery with a volt meter
has to be above 12 volts
if lower or equal to 12 volts ...no good
the charging stator inside the engine needs testing or repair or replace
stator is another word for an alternator or a generator
why it plays up
best guess the ATV if a 12 volts system wont run on 11 volts
Oct 13, 2016 | ATVs
Battery indicator light up when braking
The battery indicator light informs you that there is low voltage running through that circuit. This is usually caused by a failing alternator but a battery that wont hold charge has a similar affect. My money is on the alternator and I have replaced several of them in the past. Do you know how to test if your alternator is charging?
Jun 26, 2013 | Peugeot 405 Cars & Trucks
Samsung galaxy ace, not sure if there is water damage as the phone has not been in direct contact with water but the phone wont turn on even with the charger plugged in.
check the battery condition usually the charging IC is the one which gets affected when it is contacted by water replacing it wont cost much
Apr 10, 2012 | Android Galaxy Ace
My battery is losing a percentage of its charging capability every two days. like it wont charge over a certain percentage. today it reaches 65% and wont charge anymore
It sounds like the battery might be faulty. And you may need to get a replacement. Check out your local batteries plus store. www.batteriesplus.com.
Also something to check into is the laptop manufacturer may have a recall on the battery pack for your laptop. Over the past 5 or so years there's been a lot of recalls on them. Virtually all manufacturers were affected. If your laptop battery is part of the recall, you may be entitled to a free replacement. It's worth a shot.
Good Luck,
Mark
Apr 02, 2011 | Computers & Internet
My n96 16gb wont charge but battery charges in another phone
Hi, if you N96 is not charging when plugged to a power supply outlet and the battery charges in another phone, then it obviously means the charging i.c in the phone is bad thereby affecting the charging port.
You need to get the phone to a mobile phone repair tech to replace the charging i.c. Meanwhile you can use a desktop charger to charge your battery pending the time you fix it....
Feb 26, 2011 | Nokia N96 Smartphone
My samsung t301g wont turn on. Its been on the charger all night all it does is lights up starts to say charging battery and then dies I tried another battery and another charger still wont start up and...
WON'T TURN ON
Hi,when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
Hi, when a phone won't turn on or blinks red light, it 's either the battery cell
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery forlonger hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Jun 24, 2010 | Cell Phones
My boyfriend was trying to charge my laptop and he used a cable that had higher voltage than the netbook allowed, we then heard a zapping noise real loud and than nothing and still nothing
If your laptop is exposed to a very high current, there is not supposed to be any problem affecting the laptop, its only the charger that is supposed to be affected.
And a replacement of the charger is the solution to that.
If it goes beyond affecting the charger then The high voltage can affect only two (2) things on the laptop.
1. The battery,
2. The power panel in the laptop.
If it is the battery, To fix it, All you have to do is to get a replacement battery.
Shift the slides that are beneath the battery in the direction they are pointing to, then pull the battery back.
Replace it with the new battery you just got for it, charge it for a while, then turn it on.
If it is the power panel, the laptop will not come up at all.
To fix this, you have to unscrew the laptop from the bottom, you will see the port the charger is being plugged and the panel that is linked to the main mother board of the laptop.
Disconnect it, and apply a little force to remove the charging port of the laptop.
Replace it and reverse the process to reassemble the laptop.
Take care
Jun 20, 2010 | Acer Aspire ONE AOA110-Aw Netbook
Lumix DMC-FZ18 wont power on
Leaving it in the on mode has totally depleted the battery, you say repeated charges fail. Usually leaving it on charge for overnight should revitalise it, if this is not so then the battery should be replaced as attempting to recharge it may cause it to split and spill nasty stuff onto things.
Dont take the risk with batteries in expensive cameras they are cheaper to replace than the camera itself. I remove the batteries from my camera at the end of any session and store them in a tupperware container in my camera gear. That way if they develop a problem it wont affect the camera. It also saves them from running down when the camera switch is left on.
Please rate my help++++Thanks for using FIXYA
Nov 23, 2009 | Nikon D300 Body Only Digital Camera
Nokia 6110 Navigator Cell Phone Logo
50 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
