Question about Ricoh AC205 All-In-One Laser Printer
I have a 1 inch black line on my copies. Left to right on the 8.5 inch leading edge. Only when scanning from the glass. Never from the ADF or the computer. It does not always occur. Any help would be great!
    President:
  • Ricoh Master
  • 1,447 Answers
It is problem you copier exproser lamp mirror.Please clean it by soft cloth then solve your problem
Posted on Sep 12, 2009
Black line in paper
On what operation are you receiving the black line in your paper?
This problem usually appears when you try to scan or copy using your ADF (automatic document feeder).
To remove this black line in your paper, clean the ADF platen glass in your printer and do as well in the flatbed scanner glass. This ADF platen glass can be found right below where the documents in the ADF goes through. Its a glass about 1 inch in with and beside the flatbed scanner glass (the one where your documents is lay down for copying and scanning. Dried ink or paper residue sticked in the glass can cause this line in the paper. Clean it with a a clothe and spray some windex on it.
Feb 10, 2011 | Panasonic KX-FLB801 All-In-One Laser...
When using the ADF for scanning to pdf, it creates black lines vertically down the left side of the document. If I use the flatbed scanner, no lines.
Your machine ADF is dirty or dust in adf glass please clean it by soft cloth and scane again its clear and sharp.
thanks.
Nov 24, 2009 | Brother MFC-7820N Printer
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
When scanning or copying from either the ADF or the flatbed, my 7310 puts a black line all the way down the right side of the page exactly 1 1/2 inches from the right edge. I have cleaned the glass (and...
You can check the white guide bar that sits above the glass, any marks on there will leave a streak because it is the white reference for the scanner. after that you will probably need a new scan assembly because sometimes single elements will burn out.
Aug 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Colored Vertical Lines when ADF Scanning
the scanner system using ADF is not the same as in using from the platen glass, (CIS usually called contact image sensor) reads your document and sends the info to be printed, chances are your CIS assembly could be dirty and have some dirt on its surface, try opening this area on the top of ADF and clean with a moistened cloth, especially the affeced left margin, it should work!
Jul 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Lines through copies
The scan glass is dirty or it has a scratch on it. It can be a small dot of ball point pen ink. A small ball of tape adhesive. A hair....it is not always easy to see. Clean it with a good solvent.
Also if the ADF feeder tray is out of adjustment, it could be caused by the edge of the paper.
Nov 01, 2007 | Office Equipment & Supplies
Ricoh AC205 All-In-One Laser Printer Logo
78 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
