My Philips 26 inch CRT TV has started switching itself off regularly. Immediately prior to this starting we noticed quite bad picture distortion on the vertical plane (bowing in from the sides like an hourglass). Can this be fixed (and is it worth it)?
    Sergeant:
  • 269 Answers
Hi! the trouble you have mentioned indicates that your television's power supply is in trouble.
Posted on Sep 12, 2009
Testimonial: "Advice has given me a starting point, at least!"
Distorted sound / fuse blows off when changing amp class.
The class A switch adjusts, via an optocoupler, the bias on the output transistors.
I would check the standard bias and class A bias adjustments.
Mar 22, 2014 | Marantz PM7200 2-Channel Amplifier
My optonica(india)26 inch CRT TV has started switching itself off regularly after 1 hour viewing and restarts after 1 hour gap. Can this be fixed (and is it worth it)?
Check its timer settings. If timer settings has been set to 1 hour, this type of fault can occur. If timer setting is set to [0.00] and even if the TV behaves so, surely there will be some loose solder terminals in the horizontal output or main power regulator section. Resolder all the suspected solder terminals, by applying a little more solder. Check this site named Electro-help. Some of the faults like this are described in detail there. Pull up older posts. Try this link and select the site.
Jul 07, 2012 | Televison & Video
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
No Picture
check the blue disc capacitors around horizontal output for a burn mark.
Dec 28, 2007 | Philips 26PW6341 26" TV
Picture problem, top few inches.
hi you can get a service manual which includes schematic from this site:    http://www.download.nitd.co.uk/news.php      you will have to register with them before you can download it, but this is free.   Plus you will probably you will have to download  another free program to (shareware) to decompress and read the rar. files  I used  the one for xpwindows:  http://downloads.zdnet.com/download.aspx?&docid=284618&promo=100510
Oct 24, 2007 | Philips 27PT6441 27" TV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Television takes 6-8 times to start up or turn on
Sounds like you may have cold solder connections. Call a pro to assist in this repair. Good Luck
Aug 03, 2006 | Philips Magnavox MS3252S 32" TV
Televison & Video Logo
304 people viewed this question
Top Televison & Video Experts
Electro Med Services...
