Question about General Electric Adora GHDA670N Built-in Dishwasher
Same problem as above
I am having the same problem that you are. Luckily my dishwasher is only a week old so i will have a tech come check it out and let me know the problem. Will post back once i find out what he has to say.
    Problem Solver:
  • 5 Answers
After downloading owner's manual off of GE web site we found out that our's had been improperly installed. If the door doesn't lock it won't cycle. To re-set it can take up to 90 second's depending on the cycle. If you stop it before the cycle is done it will continue to beep 'till you close the dorr , touch the re-set button & wait 'till it re-set's.
Posted on Sep 21, 2009
Dishwasher does not turn on
This is a long shot but on some dishwashers and washing machines if the drain pump is faulty the machine will not power on. Not saying it's the case with yours but easy to check and nothing to lose
Oct 31, 2015 | Frigidaire Dishwashers
My dishwasher is a year old and the buttons don't want to work right if I push on the cycle before it will come on but wont run that cycle what should I look for
your computewr panel is shot...i purchased this sAME MODEL AND LUCKILY i PURCHASED A 4 YR EXTENDED WARRANTY ON IT..BECAUSE IT HAS BEEN NON FUNCTIONING MORE THAN FUNCTIONING..:(..WONT BUY THIS MODEL AGAIN.
Oct 08, 2014 | Maytag Dishwashers
No power to control panel
Hello
Reset the panel. Shut off power to the dishwasher, and then turn it back on. This may cause the panel to reset, which may fix certain electrical problems.
Check availability of the control panel part. Find your panel's part number in the user manual or online. Some panels for older models are no longer available. If you are sure the panel is at fault, order your replacement part.
Turn off the power before working on the panel. You can unplug the dishwasher or turn off the circuit breaker for it. Confirm that the power is off before continuing.
Follow your manual to remove the old panel. Note the settings, jumpers and wiring of the old panel before removing it. Take a picture with a digital camera to help your memory.
Find your dishwasher's tech sheet. A tech sheet is usually included inside your dishwasher. You must remove the face plate and reach up inside the dishwasher to find it. This sheet has technical information from the manufacturer for your dishwasher.
Follow your manual to install the new panel. Try not to generate a static charge around sensitive electronic equipment, or the new panel may be damaged. Check the old panel to confirm any jumpers or settings.
Restore the power to the dishwasher. Run through the test sequence for your panel, if applicable. The instructions will be on the tech sheet. Load the dishwasher and do a test load of dishes.
Sep 13, 2011 | Dishwashers
Dishwasher is reading "overfilling", but no water is in unit. Door can open, noise of motor or pump continues and will not shut off even with the Power switch. Only way to stop noise is to turn off the...
HI- The flood switch has been tripped. It is located under the unit and is not really accessible except by a Tech. The most likely cause it poor draining; if there is a little water left over from each part of the cycle then eventually the water will overfill into the pan under the dishwasher and trip the flood switch. Check the Air Gap on your sink for blockage if you have one and check the dishwasher filter inside the unit. You can just let it sit for a few days or a week and the water in the pan will eventually evaporate and the switch will remedy itself, or you can call a Tech and have them dry it out and check the drain function. Hope this helps, good luck.
Sep 24, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Jun 20, 2009 | KitchenAid Dishwashers
Water over flow on a1267302ew DWU9200ABX Maytag dishwasher
There are three common causes for water leaking from a dishwasher door or float.
1. A problem with the wash system. Check the wash arms for cracks and or splits in the underside that can cause water to jet down and out the front of the unit. Check all water supply tubing in the unit as this can cause the same problem.
2. It is not uncommon for a water inlet valve to fail open and allow too much water into the tank causing a leak.
3. Over sudsing can cause a leak. Make sure fresh dishwasher detergent is used in moderation.
Go here for Maytag Dishwasher Parts: http://www.repairclinic.com/Maytag-Dishwasher-Parts
www.RepairClinic.com
Feb 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Streaks on stainless steel tub of both kitchen aid dishwashers
Hi, Emilychee1
Do you have city water or well water?
How old is you home and the plumbing?
How long do you have the stainless dishwasher and sink?
Ill wait for you reply!!
ngafm
Sep 11, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool DU1055xtss doesn't fit cavity where old Whirlpool dishwasher exists
best bet go see your local KNOWLABLE sales rep. generally the mom and pop better then the big chains for knowing what will and wont fit your height requirements
Feb 29, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Maytag dishwasher MDBTT60AWW
if you can select different cycles such as rinse only and that light up and then if you change it to normal cycle and it light up,then that tells me you touch pad is working,Check your door switches if those are good and your touch pad is responding, i would replace cpu board.If you remove the kick plate there should be a tech sheet there you can put unit into diagnostic mode with a certain key dance if your touch pad is responding.
Nov 24, 2007 | Dishwashers
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
General Electric Adora GHDA670N Built-in Dishwasher Logo
120 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
