Question about RCA HD52W59 HDTV Projection Television
The television is on but, no sound,
The television is on but, no sound. and it is not mute, I checked. And how much would this cost to fix something like this?
  • brotherhoodc May 11, 2010
    What make of set and which country are you at
  • 525 Answers
Around $60 if your neighbor tv technician is nice
Posted on Sep 12, 2009
How do I fix a sound problem on my television?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jun 23, 2016 | Televison & Video
I have a 50 inch GE television and the sound would not come on at all how would I fix it or is there alternative way to get the sound
Jan 10, 2016 | Televison & Video
Sound just stopped is there something I can do?
Oct 23, 2015 | Televison & Video
How to fix crt sharp tv no sound
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 20, 2015 | Sharp Televison & Video
I have a Sony Bravia Model No. KDL 32M3000. There is no sound. Is there a fuse or something that needs replacing? All wired are attached.
Feb 11, 2015 | Sony KDL-32M3000 32 in. LCD Television
How to fix with the sounds? no sounds coming out
Jan 30, 2015 | Televison & Video
I have sound but no picture? What should I check or fix?
When you are having sound problems with a television you check the settings first then the connections and then the devices before concluding that the television need repair.
The quickest thing to do first is check all the devices and inputs where you have things connected to your television. For example try cable on input 1--no sound. Ok next try the DVD player on input 2--sound. If there is sound on one input and not another then that will rule out the television needing to be repaired. Granted there may be something wrong with the one input that has no sound but that is rarely the case.
Ok if there is no sound on any of the inputs and with any of the devices then check your settings. Make sure the television is not muted (I'm sure you have already done that) and check the volume bar going up and down with the remote or volume button. Make sure that your television is set for audio to come out of it and not for audio to come out of a stereo system. There is usually a setting asking whether or not you want to mute the audio on the television all the time because you're connecting it to a stereo system. The setting might be audio output select fixed (audio comes out of the tv) or variable (audio is muted all the time because you're connecting a stereo system). There may also be a reset all under the audio settings and an overall reset all, which will restore your television to the factory settings. That will normally work if nothing else if wrong with the television. Instead of a reset all from the menu sometimes a television will have a reset button or hole that can be depressed with a ball point pen.
You can also check the cables you have connected between your television and the devices because they might have gone bad. You can either try brand new cables or grab/borrow a set from another one of your televisions just for troubleshooting.
Also you can connect your device(s) to another television to see if you get sound on it.
Mar 08, 2011 | Televison & Video
I have picture but no sound. Checked for mute button, increased/decreased volume, unplugged tv and still nothing.
some sets will have an option to turn off the speakers (different from mute); this is used when you want your tv to output to a sound system with external speakers. check your menu settings for something which disables tv speakers--that is probably your issue.
Mar 06, 2011 | Vizio VO320E LCD TV
Sound is off of the television
Make sure your speakers wires are plugged and then check the you do not have mute on!
Oct 30, 2008 | Hisense TA42P40M 42 in. Plasma Television
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
