Question about Dell Inspiron 1420 Notebook
When i power up there is just a lightened black screen, no loading screen of anything
  • coltons3290 Sep 12, 2009
    well i was messing around with it once and it started to load again, but i got surious and turned it off again and nothing, i use to leave it running im thinking it over heated or something
  • roderick Guariño
    roderick Guariño May 11, 2010
    the problem maybe is the backlight of ur laptop what u need is replace the inside crt backlight but these is completed may be what u need is to go the nearest dell outlet as them about it.
    Genius:
  • Dell Master
  • 1,250 Answers
Check RAM, or take out the battery for some times then insert it again then check, if this does not solve the problem then check the display to a monitor through a vga port, if there is no display then its the fault of mother board take it to the service centre
Posted on Sep 12, 2009
  • Dell Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Plasma TV Repair
Hi ,
get the power supply checked and the screen back light too. if possible change the screen .
peace .
May 18, 2017 | Televison & Video
I have a nokia lumia 520 wont turn on and has a lightening bolt + cog wheel on the screen
Try this- Press power + volume down , keys until the phone vibrates (about 8-10 seconds). See if it switches ON ..
If not wait till the Battery is completely drained. Then connect the charger .. Leave it for about an hour and see if it has switched ON on its own .. Else try the reset once again
Nov 18, 2013 | Nokia Lumia 520 Windows Phone Black
Why is my TI-83 screen black?
If you cannot see anything on the screen, the contrast may need to
be adjusted.
To darken the screen, press 2nd and release, and then press and
hold up arrow until the display is sufficiently dark.
To lighten the screen, press and release 2nd, and then press and
hold down arrow until the display is sufficiently light
Apr 15, 2013 | Texas Instruments TI-83 Plus Calculator
All I get when powered on is a black square that is gridlike. No other controls work. All 5 batteries are new. How do I get it fixed. My location is Reseda California 91335
Try to lighten the screen reolution. Turn the calculator on, press the 2nd key. Then hold the down arrow key. This should lighten the screen. You can darken the screen also. The only difference is hold the up arrow key down until it's dark enough.
Jul 14, 2011 | Texas Instruments TI-83 Plus Calculator
My problem started out pretty confusing. One day I turned my lap top on and the screen, after about five to ten seconds of being on, went black. I could see things loading up sort of but the screen was too...
Darkened screen as you describe indicates a failing inverter. You can test this easily by plugging the laptop into an external monitor, if this works ok, then the inverter needs replaced, If it does not work, the problem is with the graphics chip / motherboard
Jan 18, 2011 | Dell Inspiron 8000 Notebook
When I turned it it has a black screen, the entire screen is black and none of the keys do anything. I replaced the batteries.
I think your keys still work, but you need to adjust your contrast. To adjust the contrast by lightening the screen, press and release the "2nd" button and hold the down arrow. Reply back if this doesn't work. Hope this solution helps!
Jan 15, 2011 | Texas Instruments TI-83 Plus Calculator
The screen is black and not allowing me to do anything
Try adjusting the contrast. Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key for a few seconds and see whether the screen lightens.
If that doesn't do it, please append a comment to this post and we'll go on from there.
Sep 04, 2010 | Texas Instruments TI-83 Plus Calculator
When i turn it on i get a black screen, all the piixels are filled but i cant see anything
Adjust the contrast. Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key for a few seconds until the screen lightens.
Mar 12, 2010 | Texas Instruments TI-83 Plus Calculator
I turn on my calc and the hole screen is black. i can see anything at all, i know that it on but nothing but black
Turn the calculator on. Press and release the 2ND key. Press and hold the Down-arrow key for a few seconds until the screen lightens.
Mar 09, 2010 | Texas Instruments TI-83 Plus Calculator
My LG Lotus main display just stopped working in the middle of a text I have tried turning it off and taking out the battery if I filp the phone open the screen lightens but doesn't display anything
Take it to a sprint store that has a repair center (check Sprint.com and click "Find a store on the top right corner for which store in your area has the repair centers). They will fix it for free or for $35. Sprint is the only national carrier to support instore repairs, and I praise them for this.
May 30, 2009 | LG Lotus Cell Phone
Open Questions:
See all Dell Inspiron 1420 Notebook Questions
Dell Inspiron 1420 Notebook Logo
245 people viewed this question
Alun Cox
