Question about Home Security
Ineed a wiring diagram for a three phase garage door
  • 986 Answers
You have a 3 phase garage door?? 480 volts? I think your not looking at it right. Please go and give us the manufactor, modle , voltage. Is this in your home or an industrial site?
Posted on Sep 12, 2009
2 Suggested Answers
  • 5 Answers
SOURCE: i need a wiring diagram for a up down and stop
Well, without the make and model of your electric operator system that is impossible to answer. If you do have the make and model try this web site. http://www.dominoengineering.com/pdfs/SRC/SRCWiringDiagrams/CommercialOperatorDiagrams.pdf
Posted on Oct 21, 2009
Essick air compressor wiring diagram
telepathy do not work that hot as in hollywood movies...
you need to provide a model or at least if this is three phase or single phase...
single phase is easy, you have cord with three wires, earth, active and neutral.
you need to open connection box on your compressor and you will find three wires there terminating in junction box, earth connect to earth (usually green or green with yellow stripes), then you have your neutral (usually brown or black) and active (usually blue or red), connect them, do not put cover on yet, plug cable into the power point and switch on/off power. check if motor is rotating in correct direction, if fuses are not blown... if motor is rotating in wrong direction - switch power wire with neutral wire, it just meant that you wired it in reverse...
do not need diagram for that...
do not forget to give some points...
Dec 30, 2013 | Park Tool Inf1 - Shop Inflator For Use...
I am trying to convert a wells f-67 to three phase and need a wiring diagram please help
Hi there.
You can download Wells F67 electric fryer at http://www.wells-bloomfield.com, it contains conversion of wiring from single phase to three phase, just click the owner's manual on Service and Support page.
Regards.
Oct 17, 2011 | Wells F-67 21167 Deep Fryer
I just need to know what my sp250 idlearc lincoln mig welder is single phase or three phase, my gurage has three phase running in how do i wire in ,if single phase
Hi:
Your Machine is single phase, and it could be a 208/230V or a 230/460/575V depending on the model. Check what kind of voltage do you have at your garage first, before attempting to do the following:
On a three phase wiring you will have 4 wires with the following colors; green, red, white and black. If you have 208/220/230 volts available at your garage you can connect the green, white and black wires, always green being the ground cable in the middle, black and white don't matter which side you screw them in.
Before attempting to connect a 480V to the machine check machine's plaque information in the front (or back) for real voltage, because this voltage can burn the PC board of you machine. The same color sequence applies to the 480V.
Good luck.
If this was useful to you, please vote.
Mar 19, 2011 | Welding Tools
Three phase house wiring, i want diagram with electrical symbols
What kind of diagram are you looking for? Large business and warehouses have 3 Phase. I've not heard of a house. but let me know. Typically 110 comes out of one breaker and one neutral wire (and saftey ground is 3rd) 220 comes out of two hot leads and one neutral wire (single phase). 3 phase comes out of 3 hot leads and one neutral but is still 220 volt.
Feb 15, 2011 | Amana Hammering
How to wire three-phase heater -model-berner mark 1 56e i have 220&110 the heater has three wires blk.rd.bl.
If this is in a home or garage you can not wire three phase as residential wiring does not have three phase, commercial buildings have three phase. Not saying it is not possible to get three phase to the house, but this could be quite costly. My suggestion is to purchase a 220 volt heater. Do not destroy the packaging it came in so you can pack it up and return it. Sorry for the bad news.
Dec 21, 2010 | Heating & Cooling
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
Wiring is hooked up wrong, need to know the wiring diagram please.
White wire with red tracer goes to terminal 1, Three solid white wires go to terminal 2 and the two white wires with black tracers go to terminal 3.
Dec 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
I need a wiring diagram for a up down and stop control for a three phase garage door motor
Sep 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Converting from three phase to single phase
Do you want to convert 3 phase to single phase?What voltage do you currently have (220v 3phase)?
May 07, 2009 | Kitchen Appliances - Others
Home Security Logo
190 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
