Question about Miele Premier-Plus Built-in Dishwasher
MIELE INTEGRATED DISHWASHER WONT TAKE IN WATER
INLET/DRAIN INDICATOR light FLASHING
  • 24 Answers
Contact Miele at (800) 843-7231
They will walk you through entering service mode on the machine to diagnose the fault code by pressing a series of buttons. At that point they can let you know what exactly is wrong with you machine
Posted on Sep 17, 2009
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
Inlet/drain light flashes on miele dishwasher and water will not completely drain away. Model G638l plus help please
the pump is blocked, need to remove the trays, drain plg, the gauze, scoop the water out as much as possible, thge thers a plastic hosing with a spring clip on top, remove this to unblock the pump. assemble & should be good to go.
May 23, 2011 | Miele 24 in. G638 Plus Free-standing...
Miele dw flashes 5 times, water is draining. Suspect filter/valve housing at end of water inlet line. Their is a wire running to this valv so I imagine whatever solenoid that tells the valve to open and...
which light is flashing? if the intake drain light is blinking and you dont hear the drain pump, it means water is not coming in. if the drain pump is running all the time, it means water has leaked into the bottom pan. behind the plastic toe kick, there is a panel that can be removed with two phillips head screws. It you can see water in there, you can dry it out, and try to run another cycle. if it runs fine, cut back on your detergent usage. if it leaks again within a cycle or two, you will need to locate the leak and repair.
Nov 18, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Dishwasher miele g646sc-the inlet/drain light flashes yet the drain system is clean and working the inlet filter is clean and the filter washed
Hi dear.If the checked lights comes on after the main wash & then flashes(when on main wash cycle,if the main pump works for a few minutes & then stops for a while & so on...)that indicates main wash pump faulty.You need to replace the motor it self.I hope that helps.Thanks.
Aug 25, 2010 | Dishwashers
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Inlet/drain light flashes on miele dishwasher and it wont start - I can hear the pump but no water - I have checked and cleaned all pipes etc
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Jan 16, 2010 | Miele 24 in. G638 Plus Free-standing...
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele Premier-Plus Built-in Dishwasher Logo
834 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
