Question about Refrigerators
We have purchased a water filter for our Whirlpool Gold (French door) refrigerator, but don't know how/where to install it. Can you help us?
  • 986 Answers
Most all Whirlpool refrigerators with a filter have the filter at the base where the 'kickplate' grill is. Simply turn it counterclockwise and pull it out. Reverse procedure to install new filter. No need to turn off water or anything like that. If you have a water filter light that requires resetting, press down and release the light switch 5 times within 10 seconds.
Posted on Sep 12, 2009
Changed filter recently now the water dispenser is really slow
Check the filter membrane specification with the old and new both are same. If the valve high water flow will gradually decrees.
Aug 22, 2016 | Whirlpool Gold 25.6 cu. ft. French Door...
Whirlpool Gold Model # GI5FVAXVQOO French door Refrigerator with ice through door is frosting up in the freezer.
your defrost drain has clogged, normal self defrost cycle should be removing water via a drain tube leading down behind unit and evaporating away. however if you were to look behind refrig in compressor compartment youll see a "drain tube" that has what appears to be a black "duckbill" grommet attached..it has more then likely failed be gumming up and preventing water to drain through.if you remove this and install part number "w10619951", should solve your problem... youll need to clear frozen drain from inside unit as well, directions i believe are in the part packet
Oct 28, 2013 | Whirlpool Gold GI5FVAXVQ 25 Bottom Mount...
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
I don know how to turn on the ice maker of a french four door refrigerator
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Aug 07, 2013 | Whirlpool Whirpool 26 cu. ft. French Door...
How do I change the water filter for the refrigerator, Samaung RF323TE
Page 13 of the User Manual explains where and how to change the water filter RF323TE User Manual
Click link below for instructions
Where Is The Water Filter And How Do I Install It on my French Door or Side-By-Side Refrigerator?
Or click HERE If you have questions or trouble navigating the Samsung site please ask questions and I will try to assist you, Thanks Sea Breeze
Mar 31, 2013 | Samsung RF323TE 31.6 cu. ft. French Door...
I have a Whirlpool Gold Conquest refrigerator model number GS6SHEXML00. It is working properly except when I open the fridge door, the light doesn't turn on. The freezer light turns on correctly. I...
George Andraws, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (George Andraws), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 17, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a whirlpool gold refrigerator. The ice
I just want to know if you solved your problem because I have the same problem.
Thanks
Oct 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
