Question about Brother MFC 240C All-In-One InkJet Printer
My Brother MFC-240C's scanner won't work.
On the computer it says error when you open the scanner. In paint the "From scanner or camera.." won't come up.
  • repunzel06 Sep 12, 2009
    Where is the Twain file located?
  • 527 Answers
Sir,
check this site for all troubleshooting tips for scanner. http://welcome.solutions.brother.com
Thanks Good Luck
Posted on Sep 12, 2009
  • 123 Answers
Try looking for twain acquire or twain select under file, import you will need to point the system to your scanner.
3 Suggested Answers
SOURCE: paper jam in brother MFC 240C
the paper ripped at the corner in little pices and it is jamed in the printer how can I remove it
Posted on May 31, 2008
SOURCE: Brother MFC-240C
lift the scanner cover until locks into the open position.
you will see the usb socket. plug it
route the cables through the trench out the back of the printer
Posted on Dec 30, 2008
I have the Brother MFC-240C printer connected to by laptop. I have Vista 64. The printer works but I cannot scan, it says connecting to computer but nothing ever happens. What do i do?
First do you have the full software installed? Select your version of Vista (32- or 64- bit) here: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc240c_all
If you attached the USB cable to the computer and the printer before installing the full software, uninstall the generic driver that you have running and then unplug the USB cable before installing the full software. (Generic OS drivers often only run the printer on an all-in-one.)
Next replace the USB cable (scanning requires bi-directional communication and thus can fail when the printer works). If you have a USB hub or print server, try a direct connection. Try starting your scan from the computer. (Launch the software (PaperPort SE) and hit the scan button, if your installation CD had a Vista compatible version. Otherwise, try to scan in Paint (File > Import from Camera or Scanner) or Windows Fax and Scan (New Scan))
Next make sure that the monitor program is running if you want to launch the scans from the unit. This is the ControlCenter 3 - and you need to set the destination buttons for the scanner in the software. Look for the Device Button tab for each of the scan icons in the software.
I hope this helps.
Aug 01, 2010 | Brother Multi-Function Center MFC-240C...
How to scan on a brother MFC-240C printer?
Use your paint program under accessories.
Start - accessories - paint - file - from scanner or camera - choose your device and follow the directions
May 28, 2010 | Brother Multi-Function Center MFC-240C...
Invalid Access to Memory Location
first turn everything off unplug the printer.hook the usb to the computer before you do anything else,then turn on the unit it should make all the adjustments.
Jul 09, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-240C
Dec 19, 2008 | Brother MFC 240C All-In-One InkJet Printer
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
The machine has a mechanical
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
Error Message: Scan Unable A6
the scanner or main circuit board is defective. Give it back to dealer due to warranty.
Jan 12, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-240C init. unable AF error message
Sure. No prob.
Open scanner cover as you would do to check for a paper jammed sheet.
Do open the plastic which runs from middle to the right side (looks like a "Z" turned clockwise). Use a small screw diver for that. beneath you will find th flat cable of the scanner. You have to reconnect the flat cable by simply sticking it into position onto the main circuit board. make sure flat cable is in good position and click the" Z  "onto the channel. Close cover then power up and do what ever you want to do with your mfc ;-)
Dec 12, 2007 | Brother MFC 240C All-In-One InkJet Printer
MY MFC-240C ISN'T WORKING
You simply have to reconnect the flat cable of the scanner to the main pcb.
Therefore you have to open the mfc by opening the scanner cover as when you have a paperjam. Loose the the blue support by pressing down the clip on the right side and pushing the support to the right.
Disassemble the "Z"-forming by carefully pressing it up at the latches which can be seen. The flat cable has to be connected to the main pcb simply by sticking it into position :-)
Error will disappear.
Nov 08, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
700 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
