Question about Radio Shack (15-2147) Remote Control
Radio Shack 5 in 1 remote has no p button
It does have a setup button but i need instructions on programing this one
  • 525 Answers
NOTE: To program a TV/DVD, TV/VCR/DVD, or TV/
VCR Combo, use the TV key.
1. Turn on the device (for example, DVD player)
and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/
DVD, CBL/SAT, or TV).
3. Press and hold P until the red LED blinks twice,
then release.
4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If
the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2
to 4 and try entering the code again.
5. Aim the remote at the device and press Power
(or Play, if it does not have a Power key). The
device should turn off. If it does not, repeat
steps 2 to 5, trying each code for your brand
until you find one that works. If you cannot find
a code that works, see “Searching for Your
Code”.
6. Repeat steps 1 to 5 for each device you want to
control. For future reference, write down each
working device code in a safe place.
Posted on Sep 12, 2009
Radio Shack telephone Cat# 43-3091 Need phone setup instructions incl. programming memory button
If you mean the Radio Shack 43-3901 then you may download a copy of the manual here.
Apr 06, 2012 | Lands Phones
How do i program this remote control Radio Shack 6-in-1 Easy Setup Voice Remote Remote Control Easy remote
Turn on the unit to be controlled manually. Press and hold Setup until the voice prompt starts the programming menu. Press 1 to directly enter a code. Press 2 to search for a code. Note at any step if the no buttons are pressed for 15 seconds, the remote will enter the usage mode. Start again from the Setup button. When prompted, press the device button for the device you want the remote to control.
Then enter the 4 digit code (if using the direct programming mode). The LED will blink twice and the remote will announce success. Test if the remote works (play, power) when prompted to test the code and press Setup if it is successful. Then wait until the remote says goodbye and then press Power again. The unit should turn off. (I strongly suggest testing other functions as well after this.) Repeat with other codes if unsuccessful.
For searching through the programmed codes, start as indicated above: press and hold Setup and then press 2. When prompted press the device button. Then press the test key (power usually). Slowly alternate pressing CH+ and power until the device turns off. Press CH- if you miss the device turning off. Press Setup to store the code. Then after the remote says goodbye check if the remote works for all the functions. Repeat the above if it doesn't work for all features.
The manual for the remote is available here: http://files.remotecentral.com/view/852-1041-1/radio_shack_15-2146_6-in-1_easy_setup_voice.html . This file is a PDF in a zip archive and does include the code list at the end.
Please note that codes in the remotes are limited to those for devices released at least 6 months before the remote was programmed. If your device is newer than your remote, you may need a new universal remote. I suspect this remote may be from 2004.
I hope this helps.
Mar 01, 2011 | Radio Shack 15-2146 Remote Control
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
What are the codes to radio shack 3-in one remote..
But the Radio Shack (15-2142) is a 4 in 1 remote. (15-2147) is a 3 in 1 remote, Which are you looking for?
Oct 20, 2009 | Radio Shack 15-2142 Remote Control
I lost my manual i have a radio shack 4in1 universal remote no.15-2114
if you have a universal remote try their website, you can also try hitting the power button on the remote severl times(maybe hundred) intil your tv turns on, then hit the enter button, this will program the tv...
May 28, 2008 | Radio Shack (15-2147) Remote Control
5 in 1 Remote by Radio Shack
i have a thirteen inch in durabrand tv i need to figure out how to program my radio shack five in one universal remote but have no book how do i do it
Apr 12, 2008 | Radio Shack 15-2200 Remote Control
Radio Shack (15-2147) Remote Control Logo
351 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
