Question about Canon PowerShot A70 Digital Camera
When i power on the camer its focus comes out but after 2 or 3 seconds it goback automatically and appear the text i.e. E18
  • 62 Answers
It may be a internal softwere error.It is better to send to a canon service center.
Posted on Sep 12, 2009
Argued for almost a year over focusing problems and methoding and "r13" problems which they said was a bad connection between the lens and the camera. When the guarantee ran out we insisted the store
The D90, is a very good camera. I even know some professionals who do have one or more, to work with or have it as a backup for a bigger Nikon, because it will work with almost every Nikon lens. That means, it also works with the older AF lenses, that were made for analog (film) cameras.
To start, put the main dial on the top left, to the green camera (auto) logo or the one with the line through the flash logo, next to it. In both cases the camera works automatic , with a little difference. In auto it will pop up the speed light when there is little light, in the other it will raise the ISO and will not use the flash. without flash, if there is not enough light, the camera just won't make a picture.
when you are in one of the automatic settings, see in the view finder, where the camera will focus while you press the shutter half. It will place one ore more squares on one or several parts of your frame, where the camera "thinks" it should focus on. It this or these parts are the points you like to be in focus, then press the button full.
this should give better pictures. If it works, let me know.
Jan 31, 2014 | Nikon D90 Digital Camera with 18-105mm...
My computer starts fine. I have a liquidvideo E19LCD1 monitor. As soon as I open Internet Explorer 8+, the screen goes dark, the analog band comes up for about 5 seconds, then the screen comes back up for...
Internet explorer can be repared as any other program.
go to control pannel.
add remove programs or Programs and features.
choose windows components.
uncheck IE.
apply .
ok
Reboot =Yes
Goback to the same place
place check mark on the IE
apply
ok
exit control pannel.
OS DISK must be kept inserted in the Drive while doing this operation because while uninstalling and installing IE. The disk is necessary
Rate this solution. coment for more explainations.
Sep 18, 2010 | Computers & Internet
The ignition switch wont goback to lock it is stuck on acc the key wont come out
if automatic trans checkshirter area must go into park before key will turn allway off
Aug 25, 2010 | 1999 Saturn SL
Canon PowerShot S2 IS camera showing code E18
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jan 20, 2010 | Canon PowerShot S2 IS Digital Camera
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
You can Try the following also;
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
E18 on Canon Powershot A95
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
take a look at e18error.com website for more info
Jul 30, 2008 | Canon PowerShot A95 Digital Camera
Canon powershot A60. When the camera is turned on there is no image won't take shots, has a number on screen E18 and shuts down after a few seconds. Mike
E18 is an error code from self diagnostic system of the camera.if there is a malfunction in the lense assembly or the focus assembly then this error code appears. You have t show it at a repair shop.
Jul 17, 2008 | Cameras
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
Getting Around Norton GoBack
try going to dafe mode if that does not work then do a system restore from dos this should fix the problem..
system restore will uninstall the norton and your files will be safe
you can also visit
http://support.microsoft.com/kb/q279736/
thanks
Jun 04, 2008 | HP Compaq dc5100 PC Desktop
Canon PowerShot A70 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
