Question about Car Audio & Video
I have a nissan sentra 2001 car i was trying to install a new car stereo and i must put the wrong wires together and all the lights on the dashboard went out what do i do????
  • 601 Answers
As far as the dash board light went out due to wrong connection, the only way to fix this is to pull the stereo out and, with a wiring diagram, re-wire the instrument panel. Unfortunately this takes time, as much as three or more hours depending on the severity of the damage. This would not be known until the technician gets into it.
Thanks
Smith.
Posted on Sep 12, 2009
I need a 2000 nissan sentra wiring diagram because my pioneer stereo was hooked up wrongn and now have no dash lights
I can provide the radio wire colors and each function of the wires by color. 2001 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Feb 28, 2018 | Nissan Cars & Trucks
I just installed a new stereo and now my running lights are always on even when I turn headlight switch off. It is a U.S. car and everything else is working fine.
There is a wire that attaches to the radio that turns on the radio lights together with the park/running lights. You must've attached that wire to a full time power source if the running lights are on all the time, right after a radio install. Recheck your radio wiring.
Jan 02, 2011 | 2001 Nissan Pathfinder
The mechanic could not fix the problem that my daughter has on her 2001 Nissan Sentra radio/clock back light doesn't work.
the reason most mechanics won't fix this problem is that it is easier and less labor intensive to just buy and install a new stereo. the back lighting LEDs are circuit board mounted and are very small. you would need to remove this deck and take it to a shop that fixes computers,stereos. mechanics are not set up to handle this kind of repairs.
Dec 31, 2010 | Nissan Sentra Cars & Trucks
Fitting a stereo in a 1993 Nissan Sentra
if you are putting an after marker stereo the wiring is different from a stock radio some audio stores sell adapters for after market stereos that you jus clip on to stock wiring
Nov 14, 2009 | 1993 Nissan Sentra 4 Door
I installed a new radio in a 1995 Nissan Sentra, now the taillights and inside dashboard lights don't turn on when I turn the car lights. check all fuses OK. radio connection ok(radio works fine). I have...
check this web site ,it might help with your question.
http://www.stumbleupon.com/s/#1Pltxs/www.modifiedlife.com/car-stereo-wiring-diagrams-and-car-radio-wiring-diagrams// its free. scroll down to manufacturer. then on rh side of screen find model and year
Nov 08, 2009 | 1995 Nissan Sentra
Hello Replaced stock radio with after market and now the dash, light don't work and tail lights blow the 10 amp fuse can you help
you have a bare wire shorting out,This is a bad condition and needs attention right away.remove the stereo and start over,you will find the bare wire or you wired the stereo to that circuit.
Sep 24, 2009 | 1996 Nissan Sentra
Stereo wire diagram
1995 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Mar 25, 2009 | 1995 Nissan Sentra
Where is the fuse of the stereo of a nissan sentra
Under the dash on the driver side.
Please rate this a fixya
Feb 06, 2009 | 2003 Nissan Sentra
Stereo Upgrade in 1997 Sentra
hi there. I am not sure about the speakers. But there is a wiring harness available for a aftermarket head unit. I have a '97 sentra the base model XE version. I have just put in an alpine head unit and you defenately hear the difference even on factory speakers. But you will need 2 kits to install an aftermarket head unit in the car. 1. A dash kit. I got mine from canadian tire for about 20 bucks, it comes with instructions on how to put it together and its straight forward, just make sure u get the one for your year and make of car.
2. The wiring harness. there available at mostly every car audio place for about 10 bucks. again make sure u get the one for your year make and model of car. installing this is difficult so unless your good at electronics get it professionally installed. you have to splice the wires into the back of the aftermarket unit, then the plugs plug right into your existing factory car harness.
hope this solves your problem, the dash kit is easy to put together and install into the car, but the wiring harness is a bit difficult, i had my harness installed for about 40 bucks and u save money if u put the dash kit togehter yourself because thats 1 less thing they have to do. good luck.
Nov 29, 2008 | 1997 Nissan Sentra
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
