Question about Magic Chef CTB1821AR Top Freezer Refrigerator
Loud buzzing noise on a Magic Chef compact refrigerator help!
I just bought a Magic Chef Compact refrigerator for my dorm and it constantly makes a loud buzzing noise and I don't know whats wrong with it
  • 221 Answers
Disconnect power from unit. Remove the cover at the bottom, rear. Examine all refrigerant tubing for contact with other tubing or other surface. Carefully adjust the tubing to prevent contact vibration.
Posted on Sep 12, 2009
Fridge makes a fairly loud popping noise at intermittent intervals...otherwise works fine and maintains wine temp as set....makes this noise approx 10-15 times a day....unable to determine any set pattern...
What you are hearing is the new refrigerant going through the system. The old Freon 12 did not make that noise but the new stuff does. Nothing to worry about, it is normal. Thank you for using Fix ya and I hope you found this info helpful.
Jun 23, 2011 | Magic Chef MCWC30MCG Compact Wine Cooler
MCBR240s Magic Chef Fridge does not cool. Compressor gets very hot when plugged in, but no cooling, it also makes clicking noises
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 10, 2011 | Magic Chef MCBR440 Compact Refrigerator
Magic chef compact refrigerater stopped cooling compreser is warm to touch and is makeing clicking noise every few minutes
heatman101
May 09, 2011 | Magic Chef MCBR445B2 (4.4 cu. ft.) Compact...
It is making a tic toc noise. It is not refrigerating. The model is : Magic Chef MCBR445W1 Thanks
the noise is from the ptc overload relay located in the lower rear on the compressor,its a safety component that aids in starting the compressor and shuts it down if the compressor overheats,unplug it off the compressor and get an exact replacement and the unit will again cool and stop tick-tocking
Mar 03, 2011 | Magic Chef MCBR445W1 Compact Refrigerator
Making a constant EEEEEEEE sound
If you are talking about a whining noise - try locating where it's coming from - it is very likely coming from your evaporator fan in the freezer, in which case you will need to have it serviced (either oiled or assembly replaced).
Oct 20, 2009 | Magic Chef MCBR440 Compact Refrigerator
Not cooling
From my earlier post, our compact Magic Chef 'frig was not running at all.  It still looks perfect, so decided to check on the repair.  It turned out to be the "starter switch," I think is what the switch was called.  The repairman said this is a very common problem, so he had the switch we needed in his truck.  It was repaired quickly and is running great.
Cost was about $140, part plus labor.  A replacement would have been only a few dollars more, but would take more time and effort.  FYI, the compressor on these Magic Chef refrigerators has a 5-yr warranty.
Hope that helps someone. Jaci
Mar 01, 2009 | Magic Chef MCBR440 Compact Refrigerator
Re: Magic Chef
If the compressor is running but the fridge is not cooling, the gas may have leaked out of the system or the compressor is inefficient. The only way to know for sure is to connect a set of gauges to the system. You will need to call in a Refrigeration Mechanic.
Nov 03, 2007 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef CTB1821AR Top Freezer Refrigerator Logo
687 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
