Question about Boss gt580 - GT580 1000W 2 Channel MOSFET Bridgeable Power Amplifier Car Audio Amplifier
Red light flashes on amp when you turn the ignition key.
Red light flashes when you turn the ignition key. have trouble shot the ground, power, RCA, and remote wires. I had the amp tested at a car audio shop and got green lights on everything so i know my amp is not blown. I used an Ohm meter on the power and groud wirs at the connection point to my amplifier and got 12.9 as a reading.( is this my problem?)
I have trouble shot to the best of my ability and have had no better result .. I know that if the amp displays a solid red(Protect) light then i need to simply adjust the ground to a better location. I am lost as to what to do know. any advise will be appreciated.
Thank you,
John Greene
    Scholar:
  • 60 Answers
It really sounds like a grounding problem. Recheck it make sure where it's attatched to the chassis is scraped to bare metal, an you used a clean, shiny bolt to attach it. Also us a voltmeter to check your power wire just to be sure it's not that, you should get 12-15 volts. Also just make sure none of your fuses are blown. And Use the voltmeter to check your REM wire, your should also be getting 12-15 volts there. If this doesn't fix your issue i'm at a loss to explain it..... Buy a new amp, and don't buy Boss, i've had lots, and lots of problems with them in the past.
Posted on Sep 15, 2009
I got a radio from the wreckers, got the code but when I turn the key on, the screen stays blank and the red light next to the word disk is flashing, what does this mean and can I fix it?
pop a disc in see what you get
screen should power up
wonder if the wiring is incorrect
should have a power constant and a power ign ,earth
speakers pos & neg ... arial if fitted
who is the maker of the radio
Oct 18, 2016 | Cars & Trucks
Kenwood kac-749s amp power indicator flashing red. what does this mean and what can fix it?
Either there is a short in the in the amp or hopefully just the speakers or wires going to the amp. disconnect any speaker input output and turn your amp back on(you will only have power, ground, and remote wires plugged in at this time) and if the red protect light goes away, then there is a problem with the input/output speaker wires, this includes your RCA's. If it's still flashing red then there may be a stray wire shorting to the amp in the speaker outs, other than that your amp may be fried. By the way, if it works without any speakers connected, including RCA's try connecting one component speaker at a time starting with your RCA's(if using them), speaker in, then speaker outs. If it turns into protect mode, note which speaker/RCA it was and replace or repair the short.
Jul 11, 2011 | Kenwood Car Audio & Video
I just bought two ten inch JL Audios and i hooked them up and they work great.... i installed them two days ago, and since then my battery has died on me twice.... i dont know what the problem is... i...
Hi there, check when you have switched off the power in the car to see if the amp power lights are still on, if so there could be a problem with your remote wire. Check the cables to he rear of your stereo and with a test meter, determine which one loses power when the ignition key is removed. When you have found this cable, splice your remote lead to this one, and your amp should switch off when you switch the car off, thus saving your battery. You could wire it to a permanent live feed and install a switch to allow you to run the amp without the key in the ignition but dont forget your battery will run down fast because Amps use a LOT of power.
May 06, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Got this amp from a friend and want to wire it up to my Sony head unit. The HU does have pre-out in RCA plugs. please help. I have tried it with: RED - stereo Amp Rem In YELLOW - 12V BLACK - -12V...
Senshin,
Red- 12 volts switched (ignition)
Yellow- 12 volts constant
Black- Ground
Blue/white stripe- remote amp turn on/ power antenna
If you have any orange wires there for the Illumination dimmer. (head unit dims when you turn the lights on). The white and gray are front speakers and purple and green are for the rear, solid being + and black striped being -. (gray and purple are right channels)Make sure that the RCA plugs go to the input side of the amp. I hope this helps, Ray
Oct 11, 2010 | Metra 705512 Ford Prm Snd Amp Plug Wiring...
The saftey red light keeps coming on
It means that the subwoofer is blown. The red light is called the Protect light. Disconnect the speaker wire from the amp and then turn the amp on and see if the red light goes away. But if as soon as you hook the speaker wires back to the amp and the red light turns on that DEFINATELY means the sub is blown.
Apr 04, 2010 | Cadence TXA 1000D High Power Mono...
I am trying to hook up an ancient Kenwood KAC-801 amplifier. The original input cable has 1 red, 1 black, then another smaller awg white (1) sharing a common with another small awg yellow. Applying power...
Yes, keep in mind that the amps have a constant power (the large red wire) and need a remote signal to tell them when to turn on/off. This wire connect to a switched 12v from the ignition or radio blue wire (if aftermarket)
Nov 01, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Red light keeps flashing..
my kicker was doing the same thing, and come to find out the power was loose,
1.check power connection,
2. check ground
3. check remote wire.
4. check that your amp isn't mounted on -metal-
5. check your fuses onboard the amp,
6.check you speaker wire
7.check your rca jacks
8. check that your gains aren't too high for the wattage
May 12, 2009 | Power Acoustik PS2-1250 Car Audio...
SOUND CUTS OFF AT HIGH VOLUME AND POWER LIGHT FLASHED RED
You need to check the DC voltage across the power and ground terminals of the amp. If the voltage drops below ~11v when the amp shuts off, you need to check the power/ground wiring and fuses.
If the voltage remains above 11 volts, you may have a problem with the load on the amp (incorrect ohm load, shorted speaker, shorted speaker wires...).
Jun 13, 2008 | Pioneer GM-X542 Car Audio Amplifier
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Jan 26, 2008 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Boss gt580 - GT580 1000W 2 Channel MOSFET Bridgeable Power Amplifier Car Audio Amplifier Logo
173 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
