Question about HP Pavilion dv1000 Notebook
The back light does not stay on after boot up
  • 32 Answers
Normally this is caused by the power inverter for the lcd. It is a small circuit board right below the lcd, that powers the backlight. If you take off the front bezel of the laptop you should be able to see it, it will have a 2 wire power cord coming out the one end, and another plug in on the other end with several wires.
9 times out of 10 the problem is just the inverter going out, check ebay for a replacment but make sure you get an identical model as the one you have, as they are very specific to each laptop. The inverter will have the part number written on it.
Posted on Sep 12, 2009
System will not boot. lights come on, disk light on for two seconds then stops. Other lights stay on. This is the same when just AC adapter is being used. Tried reseating and testing RAM. It will try...
Take out dvd-rw drive, wifi card, hdd and check usb ports for bent pins. Try booting to cmos with old memory. If this doesn't work, try new memory and cmos boot. If laptop boots to cmos, motherboard is probably okay. If not you may have MB problem. If it boots to cmos, add removed items back one at a time.
Mar 22, 2015 | Lenovo IdeaPad Y550 (41865GU) PC Notebook
My i30 boot open warning light staying on when boot is closed
Check the switch position. See if the light goes out if you manually depress the switch. If it does, raise the switch
Sep 13, 2014 | Cars & Trucks
Will not boot
Sounds pretty desperate. I suggest you find the Dell boot disk and insert it before switching on. Then come back here to report progress. Wish you luck!
Dec 16, 2013 | Dell Dimension 9100 PC Desktop
Red light n green light stayong during boot blinking light on video
have you tried booting from last known good config , and if you flash your bios by unplugging yr pc and removing the cmos battery for 10-15 mins and then replacing it back then power then turn it on that shud do the trick other wise you have a hardware issue that can only be sorted by replacing the hardware
Jan 11, 2013 | AcerPower F2 PC Desktop
BACKLITE WON'T STAY ON
You can only change the back light level in the BIOS. Boot the computer and press F2 immediately. Once you are in the BIOS, set the back light level you want, then save and exit. When the computer comes back up, that will be your back light level.
Jun 19, 2010 | Panasonic Toughbook 29 Touch with Backlit...
2004 PT, 47,000 miles, oil press light came on yesterday. Comes on, goes out, does not stay on. What does this mean. Had oil changes about month and a half ago. Only asking because I've been laid off, no...
look for the oil light switch ,then see if it has a rubber boot over it ,if it has pull it back and see if any oil inside the boot .If their is renew the oil light switch its leaking a little and the oil inside the rubber boot is causing the light to come on
Dec 11, 2009 | 2004 Chrysler PT Cruiser
Turned off engine locked door and back lights stay
relay in boot left hand side behind panel, pull out one by one till you find which one then replace
Nov 29, 2009 | 2001 Volvo V70
Boot light staying on on display
Might have to get the computer reset. The code is probably locked in.
May 24, 2009 | 2004 Ferrari 575M
No video
If it boots up then the cable is probably loose. If all the lights just come on and it does not boot then it might be the motherboard. Post back and let me know.
Jun 04, 2008 | HP Pavilion ze4300 Notebook
HP Pavilion dv1000 Notebook Logo
121 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
