Question about Sennheiser Evolution 100 G2 (SEN-EW152G2) Professional Headset
Resolder MUTE switch - Sennheiser ew100 G2 Microphone
I am trying to repair the Sennheiser ew100 G2 handheld transmitter in which the 3-pin MUTE switch came off the PCB solder pads. Both the pads and the siwtch do not look damaged. The MUTE switch is on the top side of one PCB and the PCB with the LCD is over it. I removed the Star screw that holds the PCB with the LCD but there are two pins which are soldered to what appears to go the + and - terminal of the battery holder via a plastic battery holder assembly. Then there is a 1/4" round metal stud which sticks up about 3/8" and seems to be mounted on this PCB in between the two pins. If I unsolder the two pins will I be able to remove the PCB to get at the op side of the other PCB assembly where the MUTE switch is mounted or is there something else that is attached to the 1/4" round metal piece.
4 Suggested Answers
  • 140 Answers
SOURCE: I have 3 sennheiser ew100 G2 handheld mics which
You can send them to Pro Line Music
490 Lincoln Highway
Fairless Hills PA. 19030
215-736-8055
It will cost $65. for evaluation + parts+ aditional time past 1hr. + return shipping.
Posted on Jan 16, 2010
Grubhead
  • 5056 Answers
SOURCE: I am trying to replace
See my tip on headphones jack/cable problems. Also sometimes they put on a special coating on the wires. You have to scrape the wire or file it to remove it. Spit is also good at making the solder stick!
Posted on Aug 23, 2010
djredskyy
  • 670 Answers
SOURCE: Where can I get the
Radio Shack
Posted on May 24, 2011
Mute switch stopped working. Help please.
Try to get a one track sound mixer and your problem will be solved.
Feb 13, 2015 | Sennheiser Audio Players & Recorders
Sennheiser ew100 g2
You won't need a complete short to drain the battery much faster. Unless you can compare the figures to a known working one it's difficult for you to tell what is right and what is wrong.
Is this a handheld or a beltpack? Is it a genuine unit or a Chinese copy?
A set of GOOD batteries (Duracell, etc) should last between 6 and 8 hours minimum with these units.
If you have the tools you could take the unit apart and look for signs of failed components. A partial short circuit on a board due to moisture (from sweat or other liquids) can cause higher battery usage.
At the worst case, Sennheiser fixed price repair is around 60pounds exc vat.
Mar 01, 2014 | Audio Players & Recorders
How do i sync my mic to my receiveri have a ew 100 g3 and after some kids were playing with it, I can't get any sound
Pressing the sync button whilst holding the mic close to the IR unit on the receiver should sync things back up. If this has already been done things to try next are as follows.
RF Mute. Press and release the power button. RF Mute should be displayed. Press the roccker switch and select RF mute OFF, press the rocker switch again.
Check in the advanced menu that the pilot tone is on on the handheld AND the receiver.
Jan 23, 2014 | Sennheiser Evolution G2 100 Series UHF...
I have a Sennheizer evolution g2 transmitter and reciever to go my Sony EX3 - but the input level is too low - could this have to do with the frequence I'm on?
It got nothing to do with the frequenty.
You can adjust the microphone gain in the handheld-menu. You can also adjust the receiver-output gain in his own menu.
Good luck,
Gerard
Jan 31, 2010 | Sennheiser Evolution G2 100 Series UHF...
I have 3 sennheiser ew100 G2 handheld mics which don't work properly ( rattling sound ect;)i would like to send them off to you to get a quote on how much to repair them how do i go about this.
490 Lincoln Highway
215-736-8055
Jan 13, 2010 | Sennheiser Evolution G2 100 Series UHF...
Ew100 receiver is getting siganl but no sound is coming through
Maybe the gain in the receiver is down.
You can adjust the outputgain the menu.
Good luck,
Gerard
Nov 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
On/off button broken
You should'nt need a scematic, this happens all the time with the ew100 handhelds. you will need to remove the three star bit screws between the screen and the batteries, pull off the end cover and with a small screwdriver or some long needle nose pliers- put the red button back into the hole from the inside of the cover. Just take care when putting the end cover back on- sometimes its a bit difficult.
Goodluck
PTB.
Mar 31, 2009 | Sennheiser 100/500 G2 Series Wireless...
Transmission distance problem on Sennheiser G2 wireless
I regularly use G2 ew100+300 systems, which have a manual squelch adjustment on the reciever. Squelch is difficult to explain but here we go: a squelch adjustment gives you the options LOW, MEDIUM, HIGH these settings effect transmission distance and interference rejection. for example: a HIGH squelch is less prone to interference but has a shorter transmittion distance. A LOW squelch is more prone to interferance but allows for a longer transmission distance. For most applications, a MID squelch is fine. If this does not help- the next option would be to swap arials between units and see if the problem moves. The G2 series are a 30mw transmittion which has an effective range of about 50m
hope this helps.
Rus.
Feb 15, 2009 | Sennheiser SK 300 G2 Wireless Bodypack...
All four hand held systems failed
check out override frecq see if you can change transmit and recieve switch settings ie dip switch sets sombodys overiding your freks
Dec 17, 2008 | Sennheiser Evolution G2 100 Series UHF...
Sennheiser Evolution 100 G2 (SEN-EW152G2) Professional Headset Logo
713 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michael Vincent Cruz
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
