Question about Vizio L32 32 in. LCD HDTV
Vizio 32" lcd picture inverted
Picture is good for a while then becomes inverted meaning the color is reversed. best way to describe it. thanks for help in advance.
  • 21 Answers
It would appear that your tv has a "Thermal" fault.i.e when a component gets hot it breaks down or a component is overheating. These tv,s are normally in "modular" form and as such the faulty module needs to be replaced by a qualified person.
Posted on Sep 12, 2009
How do I know which part to replace in my LCD TV...is it the backlight or t-con or main board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 23, 2015 | LG Televison & Video
Vizio VT420M has sound no picture
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 04, 2014 | Vizio L32 32 in. LCD HDTV
When I turn on my vizio tv it does not have a picture but has sound. sometimes I can turn it off then back on and I will show a picture, or if I let it warm up for about a hour. what could the problem be?
Easy fix! Shop Jimmy may have the inverter board you need. If you know someone with electronics experience show them this info. Before you purchase the inverter board, have someone pull the back cover off and locate the board. I would check the center screw, and try to tighten this a little bit. I have seen this TV not have a good ground on the inverter board and will not light up. If this does not work, order the inverter board. Please check part numbers to be correct. Thanks for asking me.
Oct 03, 2013 | Vizio L32 32 in. LCD HDTV
Why is my startup screen red and picture color rainbowish?
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight and/or an inverter board issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please revert back for more help.
Rylee
Dec 25, 2011 | Samsung LN52A650A LCD TV
VIZIO 37" LCD has sound but no picture
Good day!
that problem is happen when your inverter board is defective please replaced it..
This is the picture of inverter board.
thank you and good luck
Jun 10, 2011 | Vizio VU37L 37 in. LCD TV
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
May 12, 2011 | Vizio L32 32 in. LCD HDTV
Hello. i have a vizio vw32Lhdtv40A my screen is light up, i have volume and sound but no picture? i am confused as to y i have sound and no picture
The tv have a long board call a LCD inverter board.This long LCD inverter board is dead,that why u have picture flashes few min than dies,have sound left only.The long LCD inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Oct 16, 2010 | Vizio L32 32 in. LCD HDTV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Thinkpad screen colors Inverted/Distorted in 256 color mode
not a epert just trying to help,, i dont know what windows you are using xp or higher will not work good with that low of color,, hope this help you
Feb 25, 2010 | IBM ThinkPad T43 Notebook
Vizio vx32 hdtv no picture or control unplug to turn off
Ur LCD Inverter board is dead.Replaced this board u will get the picture back.It a long board.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board.
Feb 17, 2010 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
617 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
