We have to manually start the big washer rotor else it won't spin/oscillate. What's wrong ??
  • 64 Answers
CLUCH IS WORE OUT. REPLACING THEM GETS KINDA SPENDY BUT WILL MAKE IT WORK AGAIN
Posted on Sep 12, 2009
Samsung silvercare washer will not spin
How did you test the pump? These were my symptoms as well, and my pump was working intermittently. Sometimes, I could test the pump and it would work perfectly, and sometimes it would not work at all. Try running a load; the next time the machine won't spin, use the drain tube to drain water manually (I used a big shallow pan). There's a sensor in the washer that won't let spin start unless the water is below a certain level. In self-test mode, there's even a way to see what the machine is seeing as the water level. Anyway, let the water drain out manually with the drain tube; the machine should start spinning once the water is below the specified level. If the machine displays "Err" or "ND" before you have the chance to drain the water, you can hit pause once or twice and it will try to start the spin cycle again. To directly answer your question: If the machine will not start the spin cycle, it could be because the washer thinks the water level is not low enough to start the spin cycle. This could be because the water level is not low enough (ie a pump that's not working properly or a clogged hose), because the sensor that detects the water level is not working properly, or because the motherboard is malfunctioning. My discussion with a repair professional indicated that the pump is (by far) the most common culprit. I bought mine on Ebay very inexpensively (around $35, I think?). It is pretty quick and straightforward to disassemble the machine (check youtube for how-to videos). Just be careful -- they apparently used 2 different pumps more or less interchangeably on this model. Check if your pump is gray or black before ordering; I bought the wrong one. I made it fit because we needed the washer, but I ended up soldering the wires to the pump and re-routing some wires to make it work. It was a hassle. The electrical connector is different between the two pumps, so you'll be saving yourself a lot of hassle by ordering the right one.
Jun 01, 2014 | Samsung WF337AA Front Load Washer
Won't fill, spin, rinse, drain
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 24, 2013 | Fisher and Paykel GWL11 Top Load Washer
LG WM2455HW washer won't spin when loaded
The tub was slipping on the motor and when loaded would not spin. I noted when accessing through the back panel that the rotor bolt was loose, probably from the factory as the unit has been used less than two years. When I inspected the rotor, the plastic insert that is screwed into the rotor housing and provides the splined hole that fits over the splined shaft from the motor/stator, the plastic ridges had been destroyed. There are three screws mounting the plastic piece onto the rotor so it appears that the designers anticipated selling replacement for the plastic piece alone. So far this evening, I've only been able to find complete rotor assemblies costing $100+.
So, bottom line, your rotor may just be loose.
Sep 22, 2012 | LG WM2455 Front Load Washer
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
After final spin all the clothes end up in a big pile. the washer has never done this before. please help.
Sounds like the agitator is not working (the post in the middle that oscillates opposite the basket while in the "wash" cycle). You'd have to take the back or bottom off the washer (after unplugging it!) and check the motor and belts/pulleys that go to the agitator.
Dec 19, 2010 | Frigidaire FWSB7800DS Top Load Washer
Whirlpool Cabrio Washer
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Nov 07, 2008 | Whirlpool WTW6600SW Top Load
New timer on my washer still won't cycle properly.
SOUNDS LIKE THE MOTOR THAT ADVANCES THE TIMER IS NOT WORKING OR NOT GETTING VOTAGE TO IT. CHECK VOTAGE TO TIMER MOTOR
Jun 01, 2008 | Frigidaire Washing Machines
F&P Smart Drive #703 trouble
possible outer casing out of alinment, try lining up while doing up the bolts. Regards Engineer
Jul 08, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
