Our LG HDD DVD rh 1777 displays the HDD and DVD inputs but no longer displayes the SD STB that is linked via the AV 1 input. The program channel display also flashes now.
  • jb_ryan Sep 12, 2009
    I haven't contacted LG at all. I have the owners manual and have looked at the trouble shooting. This problem is not mentioned in the manual. I am in Australia. There wasn't a problem until a couple of weeks ago. I had heard that this has happened to a couple of LG HDDs. I am not sure if it has to do with the new channels coming on-line in Australia. Any suggestions?
    Scholar:
  • 88 Answers
  • Longtime User Sep 12, 2009
    (assuming we're talking about an HDD/DVD recorder with AV input, not a television as such) - We now have a reliable panasonic HDD/DVD recorder with auxilary input (SD) option, since last year (2008) - have had access to free-to-air HD channels continuously, no problem there. If new channels are being added here, we would simply need to set tuner to add them to the program list.
    An old JVC recorder we had before gave us lots of problems loading the control program from HDD right from when we first got it. We had it for 2 years, and it stabilised for a while, but then piked, and we could not reset it. I think the HDD just died.
    The problems you are having sound like a hardware problem with the recorder, rather than something else. If you need to get LG to look at it, then very good luck, I've heard their service is a bit variable. Their support contact number is available from the link sent in previous message.
How do I connect my TEVLON hdd dvd to strong decoder
why would you want to connect a hdd dvd to the strong decoder. Wouldn't you connect it to a television via the hdd dvd av output into the av input of the tv and then switch the telivision on input source to AV1 .
You did not mention the model number of the strong decoder but is this a digital tv to Analogue TV decoder.?
you might also have HDMI output and HDMI input on the devices .
That would be better to use if it exists. If you only have one AV input on the TV use a AV switch box and switch between the decoder and the HDD dvd device using
Jan 24, 2015 | Televison & Video
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
HDMI trouble: ''Your TV does not allow display of this program...
''Your TV does not allow display of this program through the DVI input source. Please choose another TV input source
whys it say that
Mar 19, 2010 | LG 32LG30 32 in. LCD HDTV
Cannot view / record from AV input - no option on remote
look for a source button or 1 with a square with an arrow pointing in to it both are types of av button
Aug 25, 2009 | LG DR275 Recorder
Cannot burn DVD properly
have you try copying on a different brand of cd? or better try to copy the file on the minimum speed.
hope this helps
Jul 07, 2009 | LG RH-4820 DVD Recorder
Can I copy vcr tapes with the LG RH 1999H dvd/hdd recorder?
I use the av2 input in the front of the recorder to copy my vcr tapes to the hard drive
Apr 27, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Zenith B25A10Z connected to a DVD player via modulator. We use verzon STB. Dvd will not display on TV when turned on. Remote a/v does nothing. Any help?
If you are using a modulator, usually that sends a signal to channel 3 or 4. Select either 3 or 4 and you should get the signal. The modulator should have a switch to enable you to select one of those channels. Selecting the Video input is when the DVD is connected using the audio and video cables (Red/White/Yellow)
Dan
Jul 29, 2008 | Zenith B25A10Z 25" TV
Philips dvdr3575h/37 Initial setup
Do you have two cable inputs going into your player?
May 01, 2008 | Philips DVDR3575H/37
Can't remove AV Input display
Try setting hdmi control to off in tv menu
Apr 06, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
