Question about Logitech VX Revolution 931690-0403 Mouse
Opening a Logitech VX Revolution Laser Cordless Mouse For Notebooks
Hi. I have the above mentioned mouse (model #831908), and I want to get inside to re-solder the red wire to the battery contact. If you can just tell me how to open the thing, I can do the rest. Much appreciated!
  • Anonymous Jan 01, 2008
    I have the same problem! The small red wire has broken and I cant open the case of the mouse to re-solder it. How does it open??? HELP!
  • 6 Answers
I had to open mine up today and fix the scroll wheel. Thing wouldn't keep scrolling freely like it was supposed to so I figured it just needed to be cleaned but I was wrong. I'll get to that in just a second.
First, keep reading before you go to tearing into this thing. There are 5 static patches on the bottom of the mouse. These are the little stickies that cover up the screws on the bottom of the mouse and help it slide better. There is a screw under each of the static pads and you'll need to get to all of them to open it up. To get the stickies off you will need a thin screwdriver or knife or something to pry them up with. Press down pretty hard between the sticky and the crack before you pry or the sticky part will separate from the static part and you will have to glue it back together.
Remove all the screws and the top will separate from the bottom. There is a data cable still connected between the top and the bottom so you will need to fold the top over to the side.
If you start to remove other screws inside the mouse be careful because there are some very tiny springs that can pop out and go who know where.
Reverse the procedures to put it back together and viola.
Posted on Nov 17, 2008
I had the same problem, I Peeled back the anti-friction pads with a thick screwdriver carefully cause you have to stick them again and removed the screws.Than atached the red wire.The mouse now works perfectly.
Posted on Aug 03, 2008
Peel back ALL pads and use a sharp screwdriver or similar device to do this. The first two I removed teared appart partly so i had to use glue to repair afterwards. The red wire was detached to the battery house and was too short. I used the heat of the soldering iron to release it. After reparation I glued the red wire again to the battery house. Now the mouse works perfect but the anti-friction pads are slightly damaged.
Posted on Oct 31, 2008
Yeah this totally worked! I ended up soldering the black wire, I cleaned up the connection (it was a bit greenish) and I bended the connection a bit. now my mouse works like a charm again!
Posted on Apr 03, 2010
Peel back the anti-friction pads. Screws for the case are under the pads but you are likely to distroy the pads in the process of removing them.
Posted on Jul 17, 2008
P/N 993-000028
this is the part # for the usb receiver to this mouse...it is $10 + shipping ($17.45 I think total) directly from Logitech
Posted on Jul 08, 2008
Do i have to use 2 receiver for 2 mouse?
Yes. Each mouse generates it's own datastream, and therefore requires a separate data channel. The receivers for these mice were never designed to handle more than one channel at a time. This operating system usually has no problem with more than one pointing device.
Jun 15, 2010 | Logitech Cordless Mouse
I have a sony laptop vgnfw560f to which I have installed a vx nano cordless laser mouse. The basic functions of the mouse work, however when I attempt to install the mouse software my computer does not...
probably the vx nano cordless laser mouse driver is not compatible with the operating system on your computer.
What is the operating system on your computer?
You need to download a driver compatible with it
Jan 04, 2018 | Logitech VX Nano Cordless Laser Mouse
How to connect Logitech mouse to Windows Vista
go to the logitech website. Logitech.com support. give your model #. Download the complete software pertaining to your model and plug into usb the software will recognize the mouse.
Dec 25, 2009 | Logitech 9311570403 Mouse
HI vx revolution mouse repair
no sorry, once the little pins and rollers inside have broken their isn't any way. I'm really sorry.
Dec 25, 2009 | Logitech VX Revolution 931690-0403 Mouse
Drivers
Because you don't list what model Logitech cordless mouse you have, look in this list to see if yours is on it. If it is, click on the link and download and install the driver. This download has the latest drivers and SetPoint software for Logitech cordless, wireless and Bluetooth pointing devices (mouse).
http://www.softwarepatch.com/utilities/logisetpoint-dl.html
Specifically the mouse driver is for the following models:
  • Anywhere Mouse MX
  • Cordless Mini Optical Mouse
  • Cordless Optical Mouse
  • Cordless Optical TrackMan
  • Cordless TrackMan Optical
  • Cordless TrackMan Wheel
  • G1 Optical Mouse
  • G3 Laser Mouse
  • G5 Laser Mouse
  • G500 Gaming Mouse
  • G7 Laser Cordless Mouse
  • G9 Laser Mouse
  • G9x Laser Mouse
  • LS1
  • LX3
  • LX3 Plus Laser
  • LX5
  • LX6
  • LX7
  • LX8
  • M110
  • M205
  • M305
  • M500
  • M505
  • M555b
  • M705
  • MX 610
  • MX 610 Left-Hand
  • MX 620
  • MX Revolution
  • MX1100
  • Optical Mouse
  • Performance Mouse MX
  • Racer Mouse
  • Spot Mouse
  • Tiger Mouse
  • Trackman Marble
  • TrackMan Wheel
  • Trackman Wheel
  • V100
  • V150
  • V200
  • V220
  • V320
  • V400
  • V450
  • V470
  • V500
  • V550
  • VX Nano
  • VX Revolution
  • Zebra Mouse
I hope this helps and good luck!
Please remember to vote 073d6e6.jpg and leave a testimonial.
Nov 03, 2009 | Logitech Cordless Mouse
Wrong Receiver for Logitech Vx Revolution Mouse
logitech has connection software on their site you need to run
Jul 07, 2009 | Logitech VX Revolution 931690-0403 Mouse
Scroll wheel function issue VX Nano Cordless Laser Mouse
what is your serial number and model number (PID and M/N, found inside battery compartment). some mice had a recall, and there is a list which has been taken down, which i downlaoded onto my computer.
Apr 01, 2009 | Logitech VX Nano Cordless Laser Mouse
VX Revolution Cordless Mouse for Notebooks dead as a door nail...
I see no reason that the mouse should not work. They have the Xop driver and the install software. Download both and also read henote that they are talking about in. red. I didn not download it myself. If this doesn't work you can get a common PS 2 mouse for a small amount  most anywhere including Walmart.
http://www.logitech.com/index.cfm/428/165&cl=us,en?softwareid=4338&osid=1
Dec 30, 2008 | Logitech Cordless Mouse
VX mouse for notebooks won't install or work on my computer
try to plug it into another USB port, then let the system read the device for a while (around 10 mins). if still not working, you can test your new VX mouse into different laptop just to make sure it is not defective,.
Dec 30, 2017 | Logitech Cordless Mouse
Logitech VX Revolution 931690-0403 Mouse Logo
6,025 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
