Question about Panasonic Lumix DMC-LX1 Digital Camera
My lx1 wouldn't start up. battery is fully charged.
Nothing happens when I flick the switch to on
    President:
  • 2,761 Answers
You may have a more serious problem that will require professional repair, but the problem that you describe may be due to corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Posted on Sep 13, 2009
Epc light in a 2003 Turbo-S Volkswagen beetle turned on, shut off. Next day car wouldn't turn over. How do I fix this from happening and start the car?
check battery volts should be 12.6 volts.if not battery dead.have battery charged and test if battery can be charged alternator faulty.if battery dead cant be charged replace battery.and clean battery cables if EPC warning light still flash have vechicle code scan for faulty accelerator control system or mass air flow sensor.to get vechicle started after replacing battery just turn ignition switch to the on position for 30 seconds then turn off ignition switch then start engine.
Apr 04, 2013 | Cars & Trucks
2008 Chevy Equinox would not start, turn key and nothing happened, replaced battery, ran just fine for a week. Tried to start one week later it acted like it wanted to start but wouldn't. Had ju
Usually a sign of something draining the battery.
The machine test probably showed the battery could hold a charge and the alternator was charging the battery.
You may need to have someone check for a power drain.
When the key switch is off, there may be a weak short to ground or a relay or component that is using power.
Jan 22, 2013 | 2008 Chevrolet Equinox
Optura 60 cannot be turned on
Whether you think the battery is fully charged or not this sounds like a defective battery problem. Have the battery checked.
May 05, 2017 | Canon Optura 60 Mini DV Digital Camcorder
Won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Feb 29, 2012 | Toshiba Camileo S30 HD Camcorder -...
Pioneer PRV-LX1 DVD Recorder will not initialize. It flashes please wait but nothing happens.
I found that the "plug in a keyboard and hit F1" solution did work but the problem kept recurring. I got curious and dug into it. There is a CR2032 BIOS battery on the mother board that had gone dead. It is a project to dig down to the battery but replacing it solved the problem.
Feb 16, 2011 | Pioneer PRV-LX1 DVD Recorder
Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Jan 11, 2009 | Pride Go Chair Travel Power Chair
Problem with battery,
Sounds like your battery isn't taking a charge so I would say your battery is the problem
Jun 19, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Panasonic Lumix DMC-LX1 Digital Camera Logo
89 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
