Question about Microsoft Xbox 360 Controller
Xbox controller stripped screw wont come out - Microsoft Xbox 360 Controller
    Scholar:
  • 93 Answers
I do not recommend the disassemble of your controller, however you may need to get an easy out bit to remove the stripped screw. Once out, replace with a new one.
Posted on Dec 23, 2009
Where is the reset button for a kenmore 80 washer wont stop filling water level
If this is a top loader then the vacuum line has come off of the dashpot or the water level switch is broken. UNPLUG the power-Standing in front of the washer, pry off the plastic trim strips on the left and right of the dash (control panel) Now you'll see a screw at the bottom where the strips mounted, remove ans KEEP the screws, now the dash will lift up and fold back, giving access to the parts.
Aug 17, 2014 | Kenmore series 80 Washer Motor 3363737-
Hello, I have a problem with my Xbox 360 console. I'm attempting to open my Xbox 360 for the fifth time, and this time, one of the silver screws will not come out. When I use my power drill on it, it
I actually had a problem very similar to this, although it was with one of the black screws. If the screw i indeed stripped, CAREFULLY take a dremel tool and cut a small slot into the top of the screw so that you can use a flathead screwdriver to get it out. However, do this as a last resort.
Nov 18, 2011 | Microsoft Xbox 360 Console
How can i fix my xbox controller that got the cord cut in half?
You can carefully strip the insulation away from each of the wires in the cord, and wind the copper wire or each corresponding color back together. It is important to then cover each exposed piece of wire with electrical or duct tape in a manner that keeps the different wire's metal from touching each other. Otherwise it wont work.
Mar 25, 2010 | Microsoft Xbox Console
Controller wont wirelessly connect to the xbox to turn it on and take PLayer 1 spot, but when you sync them, its syncs, but still wont take player 1 spot.
caseymcmahon
It sounds like something happened to the power button/wireless card on the XBOX 360. There is a card on the front of the console that has the power button in it. However it is also the wireless receiver for the controller as well. Now if you have tried another controller and it does the samething then it is most likely the issue is with the power button/wireless card. Now if you are still under warranty then you might give Microsoft a call about getting your XBOX fixed.
http://support.xbox.com/support/en/us/xbox360/contact.aspx
Phone numbers
Toll free: (800) 4MY-XBOX
Direct dial: (425) 635-7180
If you are not still under warranty this is actually an easy fix. What you will need the XBOX 360 open tool, torx 8 and torx 10 driver. Once you get the case off then you will unscrew the 3 screws for the power button card and then remove it and replace it with the new one. The connector is kind of like a USB port. They are real easy to get off ebay.
Hope this help,
Issken
Jan 04, 2010 | Microsoft Xbox 360 Console
Power button wont light up the only way it starts is with a wire controller it comes up to my xbox and thats it controller wont conect
tyride55
It sounds like something happened to the power button/wireless card on the XBOX 360. There is a card on the front of the console that has the power button in it. However it is also the wireless receiver for the controller as well. If you are still under warranty then you might give Microsoft a call about getting your XBOX fixed.
Phone numbers
Hope this help,
Issken
My 360 wont turn on
This i have seen before and it tells me the machines is displaying the signs of lead free solder failure (85%sure). you could strip the machine down and replacing the x-clamps at the same time do the heatgun fix if you dont have access to an IR oven.
To me it will just get worse and will definately need the x-clamps replacing AND the solder re-seating.
hope that helps in some way
www.xboxrepairkit.co.uk
Sep 25, 2009 | Microsoft Xbox 360 Console
My xbox 360 is working but no green lights are working and it will not let me conect my controler
By the sounds of it your IR board is either dead or has been damaged/knocked out. you need to strip the 360 down and theres 3 screws holding it in, take out the three screws and pull out towards you. simply replace it with another and try again.
this should fix your problem
linda
Aug 01, 2009 | Microsoft Video Game Consoles & Games
Wont recognize controllers.
try re-syncing the controllers... the little button on the front of the xbox and the little button by the left trigger... press them both at the same time
Mar 31, 2009 | Microsoft Xbox 360 Console
Xbox 360 controllers wont connect
If you have tried using the white sync button (on top of the controller) and the white sync button (in front of the 360) the RF module in the 360 needs to be replaced. It is a very simple process, take the 360 apart and 3 screws T9 are holding it in.
Jan 17, 2009 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
1,015 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
