Question about LG B2050 Cellular Phone
Lg b2050 is taking too much time to charge,it's about 5 hours.IS IT THE PROBLEM WITH BATTERY OR CHARGER?
  • 33 Answers
Buy a new battery brother
if its 4/5 years old
sometimes less charging the battery damages its potential and u need new battery.
do charge battery daily even when not in use.
Posted on Sep 12, 2009
How many hrs does it take to charge
It all depends on how much current is used to charge the battery. Say you have a 500 mah battery charging at 100 ma. It should take about 5 hours. But if it's a higher capacity battery of 1000 mah it will take the same charger more hours.
Apr 20, 2014 | Energizer Rechargable Battery with Charger
LG B2050. cannot charge battery - there is a red light top left of phone - no information in manual. Any ideas please. Do not want to buy new battery if it is the phone that is at fault
considering that the phone was released in 2005 and is discontinued it is very likely the battery is in need of replacement. ebay would likely be your most inexpensive place to get a replacement. i generally buy any replacement batteries from hong kong... takes awhile to get them. but the cost is low. one thing tho. will the phone power up with the charger plugged in ? if it will not even do that it's time to get a new phone.
robert
Mar 03, 2011 | LG Cell Phones
My phone wont turn on or charge even tho i charged it all night
It sounds like you need to replace your battery. But first, if you're using a home charger, try charging the phone with a car charger (or vice versa). If the problem is not with your charger, then replace your battery.
When you get your new battery:
1) Make sure you are using the proper charger for your phone (not one of the cheep $5 kind), and
2) charge your battery for at least 12 hours before you use it for the first time.
Click here to see a battery for your phone on eBay: http://cgi.ebay.com/NEW-OEM-LG-VERIZON-VX8560-CHOCOLATE-3-LGIP-330H-BATTERY-/250764708864?pt=PDA_Accessories&hash=item3a62bdcc00
Jan 28, 2011 | LG Chocolate 3 Cell Phone
Hello.my b2050 has a strange behaviour. i haven't use it for one year. when i'm trying charging the battery, the red led doesn't appear. the phone is functionable beacuse the battery is not totally...
Hi,After trying out the charger and it doesn't have problem, and also you tested the battery and the battery doesn't have problem. Don't you think the phone might be the problem?
You can test for the charging port where the charger is been inserted into the phone when charging a phone.It might be dirt that is making it to malfunction. You can use a brush and a methylated spirit to clean up the edge of the phone where you insert the charger.
After testing and still doesn't work, that means you might end up replacing the charger port.
You can contact a skilled personnel for help with parts.
Hope that helps
Thanks for using fixya....
Jan 09, 2011 | LG B2050 Cellular Phone
How long does it take to charge batteries?
depending on the type of battery and charger the time usually takes from 6 to 12 hrs. for a full charge. Shorter charging time will result in battery not operating to its full potential
Aug 12, 2009 | Universal Battery Charger Charges Multiple...
DSealed Lead Acid Batteries: 12v 7ah; belongs in a Liftmaster LA400 gate control box. Can these batteries be charged using a trickle charger? I'm trying to find out if it's the battery not holding a charge...
Yes you can charge the 12 volt bttery on a trickle charger. You should use a 1 amp or less charger. Check the battery every 1/2 hour or so for heat. If it get's hot you should stop charging. Power packs that have a 12 volt rating will charge your battery safer and better but will take longer (like a cell phone charger) look at the voltage ratings on the charger. You will have to adapt the plug to hook it up and test for correct pos. and negative connections. The 7amp hour batery should be fully charged by a .5 amp (500ma) charger in about 14 hours (multiply the amps times hours of charge and do not go over the 7amp hours of the battery when deciding how long to charge). After charging check voltage, it should be around 12. Let the battery set for a few hours (overnight) and check the voltage again. It should be around 12 still. A fresh charge will usually show a higher reading (called a surface charge) than a battery sitting around. 4.5 v will not operate your device, 9.5 v or higher should.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
My LG Vue has white at&t screen stays on
ok, what you need to do is take out your battery.....
it is suppose to be out for about 30 seconds to a
minute....however long that you choose.....
it is suppose to reboot your phone, its sort of
like restarting your computer....just try that and
then after you put the battery back in, just plug
in the charger and let it do it's thing.....dont turn
on for about an hour till fully charged.......
and if that doesnt work i would take it to
att to have them experiment with it
May 05, 2009 | LG Vu CU920 Cellular Phone
LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
LG B2050 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
