Question about E-Machines eMachines Monitor E15T4
Monitor blacks out
About to night ago i was on the computer and the monitor blacks out in order for it to come back in you have to trun the monitor off and wate at less two or three mintes then troun it back on can you help with this promlem thank you
  • E-Machines Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Sep 12, 2009
The monitor is only 2 years old. less then 50
If you left it plugged into the outlet, the power supply is still running 24/7 even you never trun it on! Look inside for bad caps first, see example of failed SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | Samsung SyncMaster 932GW LCD Monitor
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Nov 17, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Monitor worked last night, now its black. if i turn off the monitor and then back on the screen comes ip for 2 seconds and then goes to black. Do i need to replace my monitor? my vidio card? or my...
Reboot into safe mode, go to the control panel > device manager (in xp the device manager is in the system folder) scroll down to display adapters, try to roll back the driver....the driver may have updated last night and the new driver is not compatible. After to roll back the driver, reboot the machine and see if it updates to another driver that is stable.
Oct 16, 2009 | Computers & Internet
Screen is black. Can't see anything.
Shut it off and try hooking an external monitor up to it. Turn it on and see if there is any display on the monitor
Dec 26, 2008 | Toshiba Satellite A215-S7422 Notebook
When I turn my monitor on a "Going to Sleep" message is displayed on a black screen and then the screen goes all black. We had a power outage acouple of nights ago and the pc was on. Since then our power...
It will be video cable or related.
Responding to prior post,
Fuses have nothing to do with the video proper.
If you have a message on the screen, which says the monitor is basically working or saying the fuses and inverter is working.
That message appears with lack of video, so it can be the cable itself, possibly the video card on the computer.
Dec 20, 2008 | HP Compaq 1501 15" LCD Monitor
Screen black
if monitor light is on, check the connecting data cable if it is ok then consult a technician.
Oct 28, 2008 | Computers & Internet
Acer P221W 20in blacking out
check your graphics card wait 20 minutes or more see what comes up i recently had that or if u try everything eg replacing everything and it still don t work try rebooting the computer with the recovery disc which means it will wipe out everything programs everything.
Sep 28, 2008 | Acer Professional P211 21" CRT Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
E-Machines eMachines Monitor E15T4 Logo
287 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
