Question about Audiovox Bosch 718 World Cellular Phone
MANUAL FOR BOSCH AQUATAK 115 PLUS IN 1700 WATTS
Bosch aquatak 1200 plus
2 from the power cable and 2 that goes to the commutator circuit of the motor inbetween is the switch placed there can be a capacitor parrallell placed on the wires for suppression on the commutator side.
Apr 14, 2014 | Hammering
Roto power lance 'jet' keeps sticking
internal ceramic swivel is obstructed or broken, insert fine wire (supplied) into head then back flush head, or replace head, checkout ebay
Mar 17, 2014 | Bosch AQUATAK 115 PLUS Pressure Washer
Can't attach lance securely- falls off
replace lance or soak lance in solvent .
Feb 19, 2014 | Bosch Garden
Bosch aquatak
First off check your pressure wand / water nozzle make sure it's clean. if that doesn't help then it could be your water pump.
Jan 14, 2018 | Garden
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps. http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at: http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
Nov 08, 2013 | Bosch AQUATAK 115 PLUS Pressure Washer
Why don't i have any power on starting washer?
Could be in the spray handle and or nossle. Many years ago I brought 1 of these units ( Not by Bosch ), and the problem turned out to be in the spray handle...
Jun 05, 2013 | Bosch AQUATAK 115 PLUS Pressure Washer
A blockage in the inlet of an aquatak 115 plus.
nothing to worry about could be due to water intake,wear on nozzle or just the gauge
Oct 14, 2012 | Bosch AQUATAK 115 PLUS Pressure Washer
Where do i find the aquatak 110 plus manual to download
type in your browser aquatak 110 plus manual
Jan 18, 2011 | Garden
Bought bosch aquatak 100 pressure washer. No manual or instructions in box. Store bought at cannot help.
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
May 07, 2009 | Bosch Washing Machines
Audiovox Bosch 718 World Cellular Phone Logo
866 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Computer Repairing
Computer Repairing
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
