Question about Apple iPhone Smartphone
When I turn my phone on now all I see is the Itune logo with an USB plug pointing toward the logo - it was working fine this morning until i tried to download something to itunes
My iphone has an itune and a usb picture on the interface
That means you should connect it to computer and restore it with itunes. But if you're jailbroken or using Unlock, don't do this!
Oct 11, 2014 | Apple iPhone 3G Black Smartphone
My iphone3 is disable
The only way you can do is call up to apple and they can activate it back to normal or you may plug your IPhone into your laptop using a USB cable. Once Itune have open hold the top right button and home until the Itune logo have pop up on your IPhone screen and just restore in.
Feb 20, 2012 | Apple iPhone Smartphone
I hooked my iphone 3gs to my computer and went to add music to my ipod from itunes. It is stuck on a black screen with the usb port and a logo of itunes. I tried restarting my iphone 3gs and it wouldnt...
Hi
looks like you have try to turn on the phone while turning on you have pressed the home button by mistake and the phone was connected to computer.that put your phone into recovery mode.
You have to restore your phone by connecting your phone with itune. and on itune click on restore and upgrade,this process will take about 20 to 30 minute. you will loose everything from your phone.
thank you.
Sep 14, 2011 | Cell Phones
My apple iphone was working fine but when i have erased all its setting and content its on a hang up mode and is still on process just showing the apple logo and cannot be switched on or off plz help....
By Holding the top button and the home button, you can force your iphone to reset.
Try this: -Hold the top button and the home button on the iphone until you see silver apple logo -When you see the silver apple logo, let go of the top button and keep holding down on the home button until you see a picture of a usb to plug into itunes. -plug into itunes and restore
-if an unknown restore error occurs, usually you may have to turn off firewall, check usb cables, try different computer
I hope this helps!
Dec 14, 2010 | Apple iPhone Smartphone
My iphone turned itself off and wont turn on, ive had it on charge but still wont turn on
try holding down the home and sleep/wake buttons until you see the apple logo cycle.
sometimes it has to be held for longer than 30 seconds.
Sep 12, 2010 | Apple iPhone Smartphone
A usb and itune with a arrow pointing at my iphone screan what should i do?
restore it using itunes.then jailbreak and unlock to work properly....here's how to connect w/ itunes....you must have an internet connection to restore...
Iphone Connect With Itune
Turn Off Your Phone
Press Home Button ( 5 Second )
After 5 Second Press Power Button (9 Second )
Release Power Button
Still Holding The Home Button
Itune Detect Your Iphone In D.f.u Mode
Release Home Button
Your Iphone In D.f.u Mode With Blank Screen
done
Oct 03, 2009 | Apple iPhone Smartphone
Usb chord an arrow toward itune
Simply plug it into your computer and open iTunes. If you don't have iTunes on your computer already, then download it here.
Hope this helps!
Sep 07, 2009 | Apple iPod touch
Tryed reseting iphone now phone stop working seeing USB and itune
Try blowing at the bottom of the phone and plugging it in an out several times.
If recovery mode is not working, make sure it is plugged in.
Hold down the Power and Home buttons for roughly 7 seconds until you see the screen go out.
Wait several seconds to make sure that it doesn't power back on.
Once you have the phone off, hold down the home and power button for 10 seconds before letting go of the power button.
There should be nothing on the screen and it should appear as though it is off.
It may take several tries to do this correctly.
Does itunes recognize it now?
Jun 09, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
