On memorex tv combo model mvd1402, there is only a thin line across the screen. (verticle size?)
HELLO
This is called "Field Collapse". Line collapse is different (a single vertical line) in the centre of the screen.
But field collapse is usually a fault in the field circuit (possibly a field output IC has gone short circuit) or electrolytic capacitors have dried out. The same can happen in a CRT TV - looks as if LCD panels are the same way! I think you will have to take this to a service centre.
GOOD LUCK! (:-)
Testimonial: "Thank you for your quick response.while this is not a LCD tv but a CRT tv it sounds like the same problem.I won't fix this old technology so thank you"
I want diagram of circuit n with label
it get arrows means wich part were fixed
on board
