Question about Dell Computers & Internet
Hibernation is not enabling after disc cleanup
''HIBERNATION'' is not enabling after disc cleanup in VISTA ULTIMATE......''powercfg/hibernate on'' is also not working.........Pleeeeeeeeeeeeeez solve this as soon as possible.
  • 10 Answers
Go to this link from microsoft and fix it by downloading the fix from them. http://support.microsoft.com/kb/928897 also make sure you ran the "powercfg/hibernate on" the right way it is described below. you can re-enable hibernation by opening an
administrative command prompt and entering the command 'Powercfg /hibernate
on'. To get to this prompt, bring up the start menu by clicking the logo
button on the taskbar or by pressing the 'Windows Start' key on the keyboard.
In the search box, type 'cmd'. Do not press 'Enter/Return'. Instead, press
and hold down 'Ctrl', 'Shift' and 'Enter/Return'. In the user accounts dialog
box that appears, select the name and enter the password of the administrator
account that you created when first installing Vista and click 'OK'. You
should now be at the command prompt. Note that if you do not follow the
instructions as above, you will arrive at the command prompt but it will be
the incorrect one. The prompt should be 'C:\Windows\System32>'.
Posted on Sep 12, 2009
Testimonial: "Thanx Sir,It's really working....Thanx again."
My asus m50vc don't hibernate with win 7
You could either be out of room, meaning you have less Hard Drive space than RAM you have. Or hibernation could be disabled. You can re-enable it through Control Panel - Power Settings.
Mar 01, 2011 | Computers & Internet
Tip
How to disable and re-enable hibernation on a computer that is running Windows
The Hiberfil.sys hidden system file is located in the root folder of the drive where the operating system is installed. The Windows Kernel Power Manager reserves this file when you install Microsoft Windows. The size of this file is approximately equal to the amount of random access memory (RAM) that is installed on the computer.
The computer uses the Hiberfil.sys file to store a copy of the system memory on the hard disk when the hybrid sleep setting is turned on. If this file is not present, the computer cannot hibernate.
Hibernation is made unavailable when you set the value of the Hibernate after setting to Never by using the Power Options item in Control Panel. To make hibernation unavailable, follow these steps:
Click Start, and then type cmd in the Start Search box.
In the search results list, right-click Command Prompt, and then click Run as Administrator.
When you are prompted by User Account Control, click Continue.
At the command prompt, type powercfg.exe /hibernate off, and then press ENTER.
Type exit, and then press ENTER.
To make hibernation available, follow these steps:
At the command prompt, type powercfg.exe /hibernate on, and then press ENTER.
Type exit, and then press ENTER to close the Command Prompt window.
APPLIES TO
Windows Vista Business
Windows Vista Enterprise
Windows Vista Home Basic
Windows Vista Home Premium
Windows Vista Starter
Windows Vista Ultimate
Windows Server 2008 Datacenter without Hyper-V
Windows Server 2008 Enterprise without Hyper-V
Windows Server 2008 for Itanium-Based Systems
Windows Server 2008 Standard without Hyper-V
Windows Web Server 2008
Windows Server 2008 R2 Datacenter
Windows Server 2008 R2 Enterprise
Windows Server 2008 R2 Standard
Windows 7 Enterprise
Windows 7 Enterprise N
Windows 7 Professional
Windows 7 Professional N
Windows 7 Ultimate
Windows 7 Ultimate N
http://support.microsoft.com/kb/920730
on Nov 19, 2013 | Microsoft Windows Vista Home Premium with...
Tip
Issue with hybrid sleep feature and hibernation feature in Windows Vista
The hybrid sleep feature and the hibernation feature in Windows Vista may become unavailable after you use the Disk Cleanup Tool SYMPTOMS
To resolve this problem in Windows Vista, run the powercfg -h on command at a command prompt to enable the hibernate feature and the hybrid sleep feature.
To run this command, follow these steps:
1. Click Start , click All Programs , and then click Accessories .
2. Right-click Command Prompt , and then click Run as administrator . If you are prompted for an administrator password or for confirmation, type the password, or click Continue .
Type powercfg -h on, and then press ENTER.
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
How i can enable hibernate option
xp
To automatically put your computer into hibernation
You must be logged on to your computer with an owner account in order to complete this procedure.
1. Open Power Options in Control Panel. (Click Start, click Control Panel, and then double-click Power Options.)
2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply.
If the Hibernate tab is unavailable, your computer does not support this feature.
vista
Go to the command prompt icon in the Start menu under Accessories and right click the icon: click "Run as administrator".
Paste: "powercfg.exe /hibernate on" and hit Enter and also paste "powercfg -h on" and hit enter just to be safe.
Open Control Panel and type in "Hibernate" in the Search.
Click "Turn hibernation on or off"
Click "Change advance power settings"
Scroll to and expand the "Sleep" option.
Select "Off" to the "Allow hybrid sleep" option.
Scroll to and expand the "Power buttons and lid" option.
Select "Hibernate" for the "Sleep button action" option. 10. Select "Hibernate" for the "Start menu power button" option.
windows 7
Click the Start button, and then click the arrow next to the Shut down button.
Sleep and Hibernate located on the menu
If sleep or hibernate aren't available, it might be for one or more of the following reasons:
Dec 05, 2010 | Dell OptiPlex GX620 PC Desktop
How do I get my computer out of hibernation
To disable hibernation in vista proceed as follows: 1. Click Start followed by All Programs and then Accessories
2. On the Accessories menu Right Click on the command prompt.
3. From the drop down menu, Click on the Run Administrator option
4. The Command Prompt window will now open
5. At the command prompt type: powercfg -H off
Disabling Hibernation In XP
The Hibernation feature can be somewhat of a resource hog in XP. If you don't plan to use it, you may as well disable it.
Here's how:
1. Go to Start> Settings> Control Panel.
2. Select the Power Options Icon
3. Click on the Hibernation icon
4. Uncheck Enable Hibernation
Sep 02, 2010 | Dell Inspiron 1525 Laptop
Tip
EXTREMELY FAST BOOTUP
The trick is Enabling Hibernation:
Go to diplay properties>screen savers>power>hibernate. Check 'Enable Hibernation'. Press shift button after you click 'Turn Off Computer' in start menu.
on Mar 01, 2008 | Microsoft Windows Vista Ultimate Edition
My laptop was on hibernation. now it is not booting. please help
Hibernation is enabled by default in Windows Vista, and is one of the seven options (i.e. Hibernate) that appears on the Vista shutdown menu. Hibernate your Vista system will enable you to quickly restore to existing system state and intact workspace instead of start afresh, run programs and open your documents one by one again. If you do not use the hibernate feature in Vista, and want to delete hiberfil.sys and then recover the space occupied by the big hibernation storage file, the hibernation function can be turned off and disabled.
Unlike Windows XP, users cannot turn the hibernation on or off via Vista GUI interface anymore. Previously users can enable or disable hibernation via Power Options applet in Control Panel. This option no longer available in Windows Vista, which also enables Hibernate ability and creates hiberfil.sys by default. Instead, users have to rely on command line utility Powercf and Disk Cleanup Wizard to disable hibernation in Vista. Microsoft KB920730 provides details on how to disable and turn off hibernation on computer running Vista system. You must log on to Vista with user account in Administrators group to perform these action.
In the search results list, right-click Command Prompt or Cmd, and then click Run as Administrator on the pop up contextual menu.
If you are prompted by User Account Control for permission, click Continue.
At the command prompt, type the following command, and then press ENTER:
powercfg.exe -h off
Another easier workaround for those who’re not comfortable to work with command line is to disable hibernation and hybrid sleep feature in Windows Vista is by using Disk Cleanup wizard tool, the built-in Windows disk cleaner to delete hiberfil.sys file. The hibernation file must be enabled to access the hybrid sleep feature and the hibernation feature in Windows Vista.
Click Start button, then go to All Programs -> Accessories -> System Tools, and run Disk Cleanup.
Choose which files to clean up, either My files only or Files from all users on this computer is fine.
On “Drive Selection”, select the Windows Vista boot drive to clean up. Note that you must select the drive where Vista is installed, which normally is also the boot drive (C:) as hiberfil.sys file will be located on the root folder of it.
Once Disk Cleanup finishes scanning the system, Disk Cleanup for Vista window will open.
Select and tick the check box next to the Hibernation File Cleaner.
You can select or deselect other type files to clean or preserve from the available items or options in the list provided.
Click OK button when done.
Hibernation will now be removed and disabled.
It will solve your problem.
Dec 28, 2009 | HP Compaq Presario V3000T Notebook
How I can enable Hibernate and Stand By button? I have windows XP SP3
You can enable hibernation in Windows XP by following the steps below.
1. Type powercfg.cpl in the Run window. To get the Run window press Win key + R. Or, you can go to the control panel and click on Power Options.
2. Find the Hibernate tab and click on it. Check the Enable Hibernation check box. In case its necessary, free up some space on you C: drive by running disk cleanup or your favorite system cleanup utility.
3. Now you can hibernate your system by clicking on the Start button and then on the Turn Off Computer (or Turn Off ). You'll see three standard options, Standby, Turn Off And Restart.
Hold Shift key and you'll see the Standby button turns into Hibernate button. Click to hibernate (Still holding the Shift key).
4. Optionally you can do this: Create a batch file for hibernating, and put it on you desktop. Every time you need to hibernate your system, just double click this file from your desktop. To do this, First Open up Notepad, type the following line in it.
%windir%\system32\rundll32.exe powrprof.dll,SetSuspendState Hibernate
Then save the file as, something.bat onto your desktop. Run this batch file to hib
Or you can
manually put your computer into hibernation:
1)Open Power Options in Control Panel.
2)Click the Hibernate tab, and then select the Enable hibernate support check box.
If the Hibernate tab is not available, your computer does not support this feature.
3)Click OK to close the Power Options dialog box.
4)Click Start, and then click Shut Down. In the What do you want the computer to do drop-down list, click Hibernate.
To automatically put your computer into hibernation:
2)Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply.
3)Click the APM tab, click Enable Advanced Power Management support, and then click Apply.
4)Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Thanks
Sep 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
The option for hibernating just disappeared. Somebody told me that it had to do with the video card. I have an hp Pavilion dv2000,Vista OS. I can't find the drivers for the video card, so I can't reinstall...
the disk clean up in vista will have included a large file for hibernate file cleaner if selected to be removed hibernate is disabled
re-enable hibernate if this has happened:
How to enable hibernate option in windows vista for those of you who mistakenly deleted your hibernation file using disk clean up, to re-enable your deleted hibernation file, click the start menu and then go to all programs - accessories - Command Prompt. Right-click command prompt and select "run as administrator".
When Command prompt has opened, enter the following
powercfg /hibernate on (note the space between powercfg and /) so it's not powercfg/hibernate on or powercfg/hibernateon it is powercfg /hibernate on
This should re-enable hibernation
May 12, 2009 | HP Pavilion dv2000t Notebook
Acer won't go on standby
To put the system in to hibernation from run menu:-
1]Make sure that the system is hibernation enabled. To confirm that, Click the Start button, go to Run menu and type in Powercfg.cpl and click OK. In the Power Options Propertiesclick Hibernate tab and make sure that Enable hibernation option is checked. Click OK/Apply.
2]Now Click the Start button, go to Run menu and type in %windir%\System32\rundll32.exe powrprof.dll,SetSuspendState and click OK.
To put the system in to Stand by :-
1]Make sure that the system is hibernation disabled. To confirm that, Click the Start button, go to Run menu and type in Powercfg.cpl and click OK. In the Power Options Propertiesclick Hibernate tab and make sure that Enable hibernation option is unchecked. Click OK/Apply.
if you unning with XP you can try to solve here:
http://support.microsoft.com/kb/907477
Dec 24, 2008 | Acer Aspire T135 PC Desktop
Computers & Internet Logo
46 people viewed this question
Alun Cox
