Question about Insignia IS-LCDTV32 32 in. Television
If i used a hdmi wire for my 32" insignia will it give me a better picture quilty?
    Scholar:
  • 64 Answers
Yes, gold plated are best. Currently HDMI is the best picture clarity available.
Posted on Sep 12, 2009
Insignia Ns-15MS0832 How do I in large the TV picture when using HDMI
Hi, On your remote select menu in the list should be something called (aspect ratio) 4:3 , Zoom, Full , 16:9 etc.. These settings should make the screen larger or smaller. Also in the list should be something called HDMI for source connections (DVD, Cable box, Dish) etc. You should be using HDMI cables for these for better quality signal. Good luck.
Jun 06, 2015 | Insignia Televison & Video
Trouble connecting my insignia 32in.Tv To my DVD player
Yes you can use Just the red,white and yellow cable from your dvd player to the tv....now make sure you have it connected correctly...sometimes its easy to confused the yellow and white connections. make sure your tv is turned to Input that you have used for connecting the cables on the back....such as...input 1...select input 1 on your tv....or if it says dvd...then select dvdv on yoru tv..You can use a HDMI cable...just plug HDMI from your dvd player to your tv and select HDMI on yoru tv..Good luck
Mar 08, 2015 | Insignia IS-LCDTV32 32 in. Television
How do i get better clarity?
Set these picture settings.
Brighness=25 to 30%; Contrast = 60 to 70%; color=25 to 45% [according to your viewing taste]; Sharpness=20%.
Jul 04, 2012 | Insignia IS-LCDTV32 32 in. Television
Insignia 32 in Flat Screen
How is the input hooked up?.By cable? RGB HDMI? Check that the set is set to the right input.Check all connections first.Try a different input to see if you get Video.Good Luck.
Sep 07, 2009 | Insignia IS-LCDTV32 32 in. Television
We just purchased a 32
Hi. One suggestion would be change the leads going to your digital soure. (if you have cable or what not) If it is scart or HDMI you need a gold platted lead with each individual wire insulated. belkin and pure av make these leads which should be availble at all electrical retailers. If you are only recieving an analog signal there is nothing you can do unless you upgrade to digital. Hope this helps!
Aug 10, 2009 | Insignia IS-LCDTV32 32 in. Television
I am trying to use my 32 inch Insignia HDTV as the display for my 13 inch macbook. I got an adapter for the vga, connected everything and turned then on. The display only shows one of my desktop pictures...
--==<[ DVI to VGA vs. DVI to HDMI ]>==-- Caleb, what you really want to do to get your Macbook working with the Insignia HDTV is to >RETURN< and exchange the DVI to VGA adapter for a DVI to HDMI adapter. This is assuming your hdtv has HDMI inputs (which I'm pretty sure all the insignia ones do! I own a 1080p 32" Insignia HDTV and it has 4 HDMI's). The reason you should exchange them is that DVI and HDMI are essentially the same connector (and a better connection than VGA), the only difference between DVI and HDMI is that HDMI additionaly contains two audio channel wires. HDMI (which is a smaller version of DVI) is a digital signal and will give you perfect picture quality compared to the analog 'pc vga' type connector you were converting it to with the adapter you described (not to mention it will probably just work immediately since there is intelligent 'handshaking' that goes on with an HDMI connection, so it will tell your HDTV what resolution to use rather than it having to guess....)
I am guessing by now you solved the problem since it was in June that you posted and it's now November as I write this, but I figured you're probably not the only one who tried hooking it up that way. And most people don't seem to realize that DVI and HDMI are essentially the same type of connection, just smaller, with audio added. So someone will most likely benefit from this posting =)
Best regards, -=VRMan3D=- http://www.vrman3d.com <- 3D Screensavers and in browser 3D Mac/PC gaming for free!
Jul 17, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Jul 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
May 31, 2009 | Insignia LCDTV26 26 in. Television
HDMI Connection
Yes it does, HDMI can handle more information and provide better picture and sound. Works like this, Cable-OK, Component-Even Better, HDMI and DVI-both Digital and the best sound and video. The only way to get full HD is with HDMI or DVI. Hope this helps
Jan 17, 2009 | Philips 52 In. LCD HDTV
Insignia IS-LCDTV32 32 in. Television Logo
88 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
