Home | Samsung | HLN617W 61 in. Rear Projection HDTV Tel... | Not available no sig...
Samsung HLN617W 61 in. Rear Projection HDTV Television
Problem for Samsung HLN617W 61 in. Rear Projection HDTV Television
Not available no signal flashing remote does not work
By hooker666 on Sep 12, 2009
I have a Samsung HLN 617 W and I turned it on today and it worked fine then later this evening we turned it on with the controls on the side of it because the remote would not work and the channels were going up and down and all over the place. I tried to change the input but was unsuccessful. I held the volume button down on the side of the tv and change the input and got the menu up. It would not function properly only letting me go down the menu even when pressing up left or right. bulb is new,color wheel is new. It just keeps switching back from no signal to not available. The remote does not turn it on or allow me to use anything but the light blinks on the tv showing it is recieving a signal from the remote. It will show a picture when it is surfing the channels and there is sound. Light from the bulb can be seen when looking at the back. Color wheel can also be seen spinning the colors.
Can someone please help me with this problem. This is a great tv.
Thank you
Jason
Popular Solutions for Samsung HLN617W 61 in. Rear
Questions and Unsolved Problems for Samsung HLN617W 61 in. Rear
Do you recommend Samsung HLN617W 61 in. Rear Projection HDTV Television?
Answer
Answer
It is powering itself off.. It will turn back on ,but turns off again in a few minutes
Answer
have a 63" dlp model HLN617W and its making a grinding noise it turns on then shuts itself off... (More)
Answer
samsung flat screen keeps turning off...sound stays on...what is the problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung HLN617W 61 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
