Question about Marantz Audio Players & Recorders
Blown fuse on stereo amp - Marantz Audio Players & Recorders
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Sometimes a fuse can blow from age, or just from some sort of surge
from the power line...but then again, a blown fuse can mean problems in the unit..If you are savvy enough, unplug the unit.....and then take the cover off...remove the fuse.. you will see it in the fuse holder....be careful not to touch other components, as you could get shocked(not likely, but possible) take it out and go down to the hardware store, and get a small box of these...be sure and match the "amps" and voltage rating to the blown one.
come back and insert a new one, and do the reverse thing with the case (put the cover back on...power the unit up. if all is well, then fine...but if the fuse continues to blow...you have problems and must take it to a repairman...
Steveo
Posted on Sep 13, 2009
No power
For what amp, a Home stereo amp or a car stereo amp? Most car amps will not have internal fuses, but home stereo amps do have internal fuses. You will notice on car audio amps fuses are always plugged into the side of the amps or they have an inline fuse that is on the main power wire into it.
You have more than likely blown a Mosfet Power Transistor, very common in car amps, I'm fixing 3 of them right now with that problem. Class "D" Amps seem to have this problem on a regular basis and they are hard to get working again once they blow. You won't even see any evidence of the bad parts inside the amp either, old amps will fill your car with thick smoke and will have obvious damaged parts. Best bet is you will be looking at buying a new amp unless you paid over $500 dollars for it, it's not worth fixing, check the warranty to have it replaced by the manufacturer.
Apr 02, 2013 | Car Audio & Video
Just got a used boat with a JVC KD S590 stereo and a JVC KS AX302 amp. The stereo works fine with the in boat speakers but the tower speakers do not work, I checked them both on another system and they...
take a digital volt meter and check the power cable and ground on the amp to see if you are getting any power . should read 12.5 or more if no power then check fuses and the ground connection
if you have power then replace the equipment that not working
Oct 29, 2010 | Car Audio & Video
2000 dodge durango stereo worked fine then
Some factory radios have external amplifiers for the sound. I would check all the fuses in the vehicle and see if one is blown. That would be my guess. When the main was replaced, it might have sent a strong enough current and popped a fuse to your amplifier.
Feb 22, 2010 | Car Audio & Video
Stereo wont turn on
the fuse might of blown take it off and check the fuse
Nov 10, 2009 | Cars & Trucks
My stereo stopped working I think the fuse is blown. I don't have the manual anymore, and I need to know which one is for the stereo. Can someone help me?
http://www.motorcraftservice.com/?link=002&urlfile=/pubs/content/~WOXMUS/~MUS~LEN/42/99musog1e.pdf
number 27 it is a 25 amp fuse probably blown, it;s a switched ignition fuse so it turns power on only when the key is in ignition and in run position or accessory
I hope that works out for you.
Aug 20, 2009 | 1999 Ford Mustang Cobra
Blown radio fuse on 02 passat
its a mini fuse most likely a 15 or 20 amp
May 07, 2009 | 2002 Volkswagen Passat
My Car Stereo Broke
Fuse #13 15 Amp located to left of steering column in dash. Radio, cig lighter and lcd display.
Mar 29, 2009 | 1996 Jeep Cherokee
Blown fuse on sub woofer
1 amp 250-volt from radio shack #270-1021
Dec 28, 2008 | Dahlquist QX-4A Main / Stereo Speaker
Blown fuse
Buy at Radio Shack. 1.99
1.5A 250V 3.6x10mm Fast-Acting Ceramic Fuse
Apr 06, 2008 | KLH KL2400 Tuner
125 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
