Question about Dryers
Dryer will not heat. It does turn-blower is working.
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house.
Posted on Sep 12, 2009
  • Dryers Master
  • 8,220 Answers
Continues to blow the high temp stat. I clean the blower and replaced the venting. I also replaced the heating coil the dryer heats up for a load and then it stopss heating. I test the high temp stat
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Feb 17, 2015 | Dryers
My dryer does not blow hot and will not shut off and no digital reading will display.
Hello Bryan;
My name is Peter. I am a retired field service appliance technician.
So, here are the probable causes:
1.) The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may be plugged up or not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft. Check the blower hot air discharge manifold for blockage.
2a.) If the dryer won't stop, the gas valve solenoid coils might be defective. Over time these coils will fail, causing the burner to run intermittently. If the dryer is not heating properly it may not stop. Replace the coils as a set.
2.b) The heating element warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element isn't working - which greatly increases the drying time. Check the heating element for continuity.
3.) Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
4.) Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or shorted
5.) If the dryer won't stop, check the high limit thermostat. If defective, the high limit thermostat can turn off the heat prematurely, lengthening the time it takes to dry a full load. This is not common.
6.) The cycling thermostat regulates the temperature of the air in the dryer. If the dryer won't stop, it may be caused by a defective cycling thermostat turning off the heat too early. This is not common.
7.) The thermistor senses the temperature of the air in the dryer and cycles the heat on and off. If the dryer won't stop, the thermistor may be defective. This is not common.
Nov 16, 2014 | Dryers
Dryer only works on 1 setting and is not heating
If your dryer is not heating assuming is a gas dryer. It could be due to The electrical fuse igniter is not working or no gas is going in. Need to remove the front bottom cover and check that the fuse is igniting when you turn on the dryer. You should hear a clicking noise just before the igniter turns red ( glowing) to receive the gas and create the flame to then produce the heat. If you are not able to see the fuse/igniter conduct this process, you might need to replace it.
Nov 16, 2013 | Kenmore Dryers
Model pye2300ayw turns on but will not heat . I checked for obstruction and pulled duct off to check but still no heat,
When you pull the duct off and turn the dryer on, do you feel air coming from the back of the dryer?? If you do, that means the blower is working. The most common failure on electric dryers that are no heat is a heater coil or element. These are usually pretty easy to replace. Please make sure before you do any work to the inside of your dryer you unplug it! Before you attempt to diagnose the heater coil, make sure the vent line inside the dryer and at the blower is clear of all debris. This could be the problem. There are instructions on this website to take a dryer apart. There are also instruction to diagnose and replace the heater coil.
Feb 05, 2011 | Maytag PYE2300AY Electric Dryer
Kenmore dryer, not heating and blower not working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 09, 2010 | Dryers
Dryer is not heating enough to dry clothing. The problem started with the electric braker box switch triped i had to replace it, dryer would turn on but no blower, I took a look at it and found some...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
87gh
Dec 09, 2009 | Estate TGDS740JQ Gas Dryer
Dryer seems to be operating properly, it heats up, but the clothes aren't getting dry. I noticed the lint collector isn't collecting much lint, is it possibly the blower?
Could be a stripped blower wheel. Remove the front panel. Rotate the blower wheel and look for loose movement on the motor shaft. If that does not work,turn the dryer on with a NO HEAT setting and run it. See if the blower wheel is slipping. If the blower is OK,check the exhaust vent for blockage.
Sep 24, 2009 | Maytag PYE2300AY Electric Dryer
Estate dryer electric, heating element gets hot but motor does
shut off power to dryer. take front off dryer,remove belt from motor and idler pully (if there is one) try turning the motor shaft by hand. if it doesn't turn ,take off back of dryer and remove blower housing and see if anything is blocking the impellers.. if not any of these then you may have to get professional help it may be a bad motor or timer
Jan 22, 2009 | Estate EED4300SQ Dryer
Ge harmony dryer not heating up dpgt750ec1pl
If you hear the blower ramp up when you start the dryer and if slowly ramps down or quits all together then you need to replace the blower. If the dryer heats at all then look at the blower.
Jun 20, 2008 | GE Profile Harmony DPGT750EC Electric...
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
55 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
